| Author |
[Modern View]
| BAnNC
10-31-2012 06:27:38
74.250.188.207
Used to be a mag that ran this challenge every few months. Count the number of cylinders on equipment you use (not counting junk or show only) and see what you come up with. ie: Super 55 4 pickup 6 Cub Cadet 2 weedeater 1 blower 1 Total 14 See what you come up with. Totals might suprise you. |
| Mark6005
10-31-2012 18:06:20
70.225.166.71
Re: How many cylinders? in reply to BAnNC, 10-31-2012 06:27:38
| Brian Allen
10-31-2012 17:39:19
74.198.87.62
| Tractors, backhoe, crawler, cars, truck, lawn equipment = 36 |
| wolfman
10-31-2012 16:48:10
174.140.65.158
| wolfman
10-31-2012 16:48:10
174.140.65.158
| Steve Terplak
10-31-2012 15:23:30
184.20.59.142
| Pickup -8 Car-4 Wife's car -6 MF 165 -4 MF 265-4 MF 'hoe -4 MF 1080 -4 Dozer -6 AC G -4 4wheeler -2 Mower -1 Chainsaw -1 (2) Mower -2 Total 51 |
| Thomas (AB)
10-31-2012 13:24:25
68.171.231.81
| Should be right around 52 currently running/ in use. Another 14 not running, or for show. |
| rustacres sd
10-31-2012 11:12:46
208.88.136.10
| 74 Gleaner K - 6 72 Gleaner K - 6 Masey 135 - 3 IN 966- 6 z-turn - 2 Cub cadet Lawn tractor - 2 weed eater - 1 chainsaw - 1 Tiller - 1 transfer pump - 1 Auger Motor - 1 Push Mower - 1 Spare motors - 2Total - 33 off the top of the head. |
| ShadetreeRet
10-31-2012 10:59:20
184.4.21.191
| 76 F150--------8 86 F150--------8 93 Intrepid----6 TO-30----------4 Riding mower---1 push mower-----1 weed eater-----1 hedge trimmer--1 chain saws-----3 portable gen.--1 Total---34If I included all the "round tuit" projects,---- well, I don't have all day. |
| I luv Farmalls
10-31-2012 10:13:11
207.199.209.26
| wisbaker
10-31-2012 09:29:48
207.118.181.192
| If I compare to my Grandad He'd win They ran 10 IH KB-7's a GMC tank truck and three GMC dump trucks plus his Desoto FireDome, throw in the lawn mower and he was at 92. |
| Paul from MN
10-31-2012 09:27:23
24.179.131.207
| Frank Dodson
10-31-2012 09:26:31
98.66.3.12
| Oliver 550 4 Farmall cub 4 NH 3930 3 Yanmar 1401 3 Mit. dozer 4 JD 280 mower 2 JD 225 zero 1 JD CX Gator 1 Troybilt til. 1 2 weedeaters 2 1 blower 1 2 mini tiller 2 chain saw 1 push mower 1 Oliver 75 1 F, Sporttrac 6 F. F150 8 Total 45 |
| oldtanker
10-31-2012 08:41:58
66.228.255.239
| casenut1
10-31-2012 08:37:50
107.8.39.45
| wisbaker
10-31-2012 08:34:45
207.118.181.192
| 46, 49 if I count the air compressors. |
| FBH44
10-31-2012 08:29:13
64.85.220.110
| Compate that to how mnany your Pop had, maybe 2 or 4, and compate to your Granpa, maybe 1 on a pull-type sprayer.... |
| old
10-31-2012 08:26:49
209.86.226.27
| To many I would loose count before I added them all up. I have over 15 running tractors alone then you start counting lawn mowers and cars and trucks |
| David R Inman
10-31-2012 08:19:52
150.135.210.70
| 68 for frequently used. 76 for good running stuff. At least 274 with all the someday projects included. funny, the closest two to show tractors are the two that most frequently see the field, but we have taken the time to refresh their appearance. |
| charlie M
10-31-2012 07:57:57
74.41.94.226
| Ever figure up how many quarts of oil all this stuff takes on a yearly bases for oil changes? |
| BAnNC
10-31-2012 09:05:06
74.250.188.207
Re: How many cylinders? in reply to charlie M, 10-31-2012 07:57:57
| rustyplow
10-31-2012 08:26:18
75.51.124.12
| I did this spring. Found out I could buy it by the barrel and not have much left over. |
| caseyc
10-31-2012 07:50:18
75.102.189.131
| | 54 daily/weekly use. Another 50 or so for a rainy day. Casey in SD |
| Fordfarmer
10-31-2012 07:36:29
69.179.12.16
| cars - 20 truck - 10 tractors - 21 combine, swather, s/p mo-co - 16 lawn mowers - 2 total - 69...unless you want to include projects, then add 16 more |
| rustred
10-31-2012 07:31:33
72.172.100.113
| i dont have that much spare time on my hands, as a guess 500. |
| DeltaRed
10-31-2012 07:28:37
67.6.219.50
| Fixerupper
10-31-2012 07:25:01
100.42.82.30
| Well, lesee, Oliver 88------6 cyl Case SC--------4 cyl IH 1086--------6 cyl Deere 4650-----6 cyl Farmall B------4 cyl Deere 630------2 cyl Dodge pickup---6 cyl Chevy Colorado-5 cyl dodge pickup---8 cyl Mower----------2 cyl weed eater-----1 cyl Chain saw------1 cyl transfer pump--1 cyl transfer pump--1 cyl Ford 9N--------4 cyl Total----------56Too many pickups!!!!! |
| grampy
10-31-2012 07:21:26
72.36.56.51
| Just tractors & the backhoe around our place add up to 44, if the 8N counts. Too tired or brain dead this AM to count the rest. Ken |
| MFPoor
10-31-2012 07:14:14
72.4.0.230
| | "Not counting junk"????Why exclude IH like that? Anyway, 98 if I'm counting 'em all. |
| toolz
10-31-2012 07:09:24
206.221.154.149
| I'm up to 244, but I'm sure I missed something. |
| rustyfarmall
10-31-2012 07:07:42
216.248.71.226
| The list would be quite long, but it totals up to 33 cylinders for equipment that sees somewhat regular use. |
| D Slater
10-31-2012 07:06:36
184.15.14.249
| Lawn mower 1 chain saw 1 weed eater 1 generator 1 3, 4 cylinder tractors 12 Pickup 8 total 24 |
| olliekid
10-31-2012 06:59:01
199.18.34.47
| Oliver 1655- 6 Dodge Ram 2500- 8Total= 14 |
| buickanddeere
10-31-2012 06:56:34
184.151.61.79
| Should I count the blades on the gas turbine |
| GVSII
10-31-2012 09:13:08
74.71.178.71
Re: How many cylinders? in reply to buickanddeere, 10-31-2012 06:56:34
| Quoting Removed, click Modern View to see
Only if those blades are cylindrical.None of the G/T I've worked on had cylindrical blades. |
| buickanddeere
10-31-2012 11:55:40
184.151.61.79
Re: How many cylinders? in reply to GVSII, 10-31-2012 09:13:08
| Centrifugal/radial rather than axial so it"s fins instead of blades come to think of it. |
| rrlund
10-31-2012 06:52:43
207.241.137.116
| Super 55 4
66 4
77 6
1550 6
1600 6
1850 6
2-135 6
combine 8
pickup 8
corn rake 1
mower 2
weed whacker 1
chainsaw 1
4 wheeler 1
Looks like 60 since you're leaving out show tractors and the wife's pickup.
This post was edited by rrlund at 09:26:23 10/31/12. |
| olliekid
10-31-2012 07:20:10
199.18.34.47
Re: How many cylinders? in reply to rrlund, 10-31-2012 06:52:43
| batractorman
10-31-2012 07:14:16
74.250.188.207
| Guess whether you include hers or not depends on how much you think she work with hers. |
| JohnDeereJimOhio
10-31-2012 09:01:53
204.9.147.16
Re: How many cylinders? in reply to batractorman, 10-31-2012 07:14:16
| Lots of tractors not a lot of cylinders: Gw-2 g-2 70d-6 720d-2 730d-6 B-2 B-2 420c-2 super M-4 T.O. 35- 4 Trucks-24 So 56 |
