Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Overcharging system
[Return to Forum]
JimS
10-29-2012 14:06:25
209.148.97.97
I have a 1990 Dodge Diesel truck. For some reason, the charging system only seems to last about six months (this has happened at least 4 times). Around that time, the voltage regulator (which is a separate unit) fails, the alternator over charges, and the battery blows up, literally.
I have a good rebuilt Bosch alternator, or at least the best Pep Boys has (I know, but I was next to one when it failed). I got the best voltage regulator Napa has, and I have the stoutest Die Hard that they sell (again, I know, but there is always a credit on it for replacement).
I am most suspect of the regulator. One time when this happened I had to install three before I found one that worked. I understand the regulator will handle an overcharge of about 14 volts, any higher and it fails. What I cannot figure out is why the alternator keeps over charging (an independent shop says it is overcharging and so does Sears, but they say it is a little over. Pep Boys insists it is fine).
Can anyone suggest anything else that may be the problem? I cannot imagine shorts causing an overcharging problem, in fact it should have the opposite effect.
Thaks for your help;
JimS
[Reply]   [No Email]
MSM
10-29-2012 15:37:13
75.192.166.255
 Re: Overcharging system in reply to JimS, 10-29-2012 14:06:25
The regulator grounds through the case to the firewall, is most likely loosing it's ground. Make sure you have a good clean area(shiny metal) where the regulator bolts to the firewall. I would also run a separate ground wire from one of the regulator mounting bolts to the engine block or to the negative battery terminal.
[Reply]  [No Email]
JDseller
10-30-2012 18:15:26
208.126.196.144
 Re: Overcharging system in reply to MSM, 10-29-2012 15:37:13
MSM has half the problems solved. You need to run a ground wire directly from the regulator to the alternator. Then go to a good local alternator repair shop. The one I use is: Sheehan Auto Electric, 395 Desoto Ave, East Dubuque, IL. Tel: 815-747-6110. They have a much heavier regulator. It will cost about three time the what the cheap one cost but last for years. I have a 1990, 1992 and 1995 Dodge diesels. They all had the issues with the charging system. After I installed a separate ground wire and a good regulator I have not had any issues with them.
[Reply]  [No Email]
Ralphwd45
10-29-2012 15:32:39
66.243.226.232
I don't know anything about the newer Dodges, but the Dodge pickups that I have, and have had, were from 1972 to 1980. They will overcharge, enough to blow out 12 vt headlight bulbs, and the only cure was to change ammeter units, or remove ammeter and put a screw and nut thru the two ammeter wire lugs, and make sure they were darned tight! I have had 3 trucks burn up the wires terminating at the ammeter, and ruining the ammeter unit.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
