Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: What A joke W/Pix
[Return to Forum]
LOU from Wi.
10-25-2012 20:26:13
72.160.225.99
Bought this POS 3 years ago to take care of the leaves, Yea Right. Up until this year so far so good. Son was making the 4th round this week sweeping up leaves when the B&S OHV engine decided to slip a push rod .Oil was pumping into the carb thru valve cover hose. Stopped and hauled it to the shop, took the engine down,re positioned the rod, so now I'm not going to trust it again for next year, Another engine but not an OHV POS.We don't mistreat our equipment,just a bad design idea from B&S.Now wondering if you folks have had the same experiences with this engine? Regards LOU. PS this is hooked on our garden tractor,so it is tractor related.lol
[Reply]   [No Email]
wisbaker
10-26-2012 17:32:30
207.118.181.192
 Re: What A joke W/Pix in reply to LOU from Wi., 10-25-2012 20:26:13
I have a B&S intek engine on my snow blower and have been quite happy with it. this will be the 7th season for it, I've changed oil & plugs nothing else. It starts easy if I remember to turn the gas back on. We're an hour north of Green Bay on the Mi/Wi line so we get a fair piece of snow, although not as much as when I lived up near Marquette.
[Reply]  [No Email]
DScott
10-26-2012 12:35:03
50.194.3.155
A friend of mine bought one of those vacuum units from TSC last year. Brought it home and cranked and cranked on that thing until he about had a heart attack. He took it back for a refund. I swore off B&S engines several years ago for the same reason, they are junk.
[Reply]  [No Email]
ih10020
10-26-2012 09:10:02
207.119.116.33
I use Marvel Mystery oil in all lawn equiptment & tillers, have for years with no valve proplems. Most are Kohler engines which are known for sticking valves.
[Reply]  [No Email]
Fred from MO
10-26-2012 07:00:32
69.55.155.226
I have a briggs flathead engine I rebuilt in 1986 and I still use it to mow grass every week.
[Reply]  [No Email]
LOU from Wi.
10-26-2012 10:55:04
72.160.225.99
 Re: What A joke W/Pix in reply to Fred from MO, 10-26-2012 07:00:32
Fred from MO, Thats exactly what we're after.They can keep the OHV design.
LOU
[Reply]  [No Email]
Achin' Back
10-26-2012 06:00:43
173.188.60.141
Lou,
Had one exactly like that. Used it for 13 years to pick up Fall leaves only. It worked flawlessly. I then gave it to a buddy in '08 and it's still running. It was great at picking up those huge Catalpa leaves and seed pods I had in my 6 acre yard
[Reply]  [No Email]
Bret4207
10-26-2012 04:53:08
64.19.90.196
Had a similar deal with a vertical shaft 25HP B+S. Push rods kept popping out, then the rocker arm bolts let go. Not a good design IMO. They do have an industrial series engine that seems to work a lot better, but you won;t find them on Sears or other consumer grade stuff.
[Reply]  [No Email]
LOU from Wi.
10-26-2012 11:06:34
72.160.225.99
 Re: What A joke W/Pix in reply to Bret4207, 10-26-2012 04:53:08
Bret4207, that seems like this design, I wonder why they put a bad designed engine on a good piece of equip?Doesn't say much for their quality.Tempted to use a "redneck" solution, put a bungee cord around the pushrod to hold it in place. Thanks for the reply,LOU
[Reply]  [No Email]
RGMartin
10-26-2012 03:33:28
173.189.139.67
That generation of B&S engine are really sensitive to old gas. Been there done that. Old gas means pre-detonation and sticky valves=bent push rods.
Those engines are fine, but require fresh gas. When you are done with it for the year make sure you drain it, and run all the gas out of the carb.
[Reply]  [No Email]
LOU from Wi.
10-26-2012 11:12:20
72.160.225.99
 Re: What A joke W/Pix in reply to RGMartin, 10-26-2012 03:33:28
RGMartin,Thanks,
We always use new gas, and drain all the fuel and add a couple of tsp of oil to the cylinder,clean the plug,and powerwashing the units, at the end of the season.Saves trouble starting it up next seasons use.Takes a while to do all the engines in the fall, but well worth the time and hassle of fixing and trouble shooting next year.Just can't understand this type of problem from a reputable engine manufacturer.Sure diminishes our opinion of them.
Thanks for the reply, LOU
[Reply]  [No Email]
Uncle Ernie
10-26-2012 03:21:41
64.38.158.247
Lou,
Other than the engine issue , how do you like the lawn vac? I am looking at buying one just like it and would like to hear "from the man that own's one"!
[Reply]  [No Email]
LOU from Wi.
10-26-2012 11:02:19
72.160.225.99
 Re: What A joke W/Pix in reply to Uncle Ernie, 10-26-2012 03:21:41
Uncle Ernie,
The machine is marvelous,except, the engine. Saves alot of time raking,blowing and carrying. We use the leaves for compost, the mower and the vacuum chops them up fine enough to break the leaves down quick. The extra 4" hose is nice for areas you can't fit the mower and cart into.You just have to watch out for limbs and rocks so it won't plug up,or damage the blades. We also have a chipper shredder that we use to further cut the leaves into finer pieces.The limbs and branches are also run thru the chipper shredder and used on the banks of our sand hill.
I don't think you would be disatified with it,provided the engine doesn't do what ours is doing.We never mistreat our equip. too expensive to replace. We was looking at the DR until the price came up,way too many zeros at the end of the number.LOL
Lou
[Reply]  [No Email]
Traditional Farmer
10-26-2012 03:07:19
67.233.70.253
Replace it with a China made Honda clone it'll last for a long time.Briggs engines are some of
worst built these days that I've owned.The old Briggs flatheads were some of the most durable around.
[Reply]  [No Email]
LOU from Wi.
10-26-2012 11:16:05
72.160.225.99
 Re: What A joke W/Pix in reply to Traditional Farmer, 10-26-2012 03:07:19
Traditional Farmer,
We're with you.Flatheads are the answer for us.We figure we have all winter to find a "better" engine. The new engine claimed "progress" PHOEY!! Older design worked for years with minimal repairs, if taken care of.
[Reply]  [No Email]
s.crum
10-25-2012 21:12:17
67.142.181.21
You honestly expected a B&S motor to run more than a hundred or so hours without having to tinker it ? All B&S makes is Walmart lawnmower engines these days ! I've got a 4 year old B&S pressure washer with the B&S 6 HP motor. It has about 100 hours on it and last year the ignition mag went bad on it, then this year the first time I tried to use it it popped twice and had no compression. Why would I need the exhaust valve seat to stay in the block? I lined the seat back up and into the block and staked it with a prick punch and so far so good, But if you want any degree of dependability, you might want to look at a Honda engine.
[Reply]  [No Email]
LOU from Wi.
10-25-2012 21:17:46
72.160.225.99
 Re: What A joke W/Pix in reply to s.crum, 10-25-2012 21:12:17
s.crum, We're begining to believe you.What a shame,they used to make bullet proof engines.If we wanted a cheap design, we would have bought a China engine that runs on rice wine,and uses water buffalo dung for lubrication.Thanks for the Honda recomendation,Guaranteed the old engine WILL be replaced with something better.
LOU
[Reply]  [No Email]
Jon Hagen
10-25-2012 20:58:09
69.26.17.61
Put Mobil 1 synthetic 5-30 or 10-30 motor oil in it and you will not have valve sticking trouble with that motor. Besides that it will start easier and use less oil.
They run a little too hot for mineral oil, which cokes up the valve stems and causes valve sticking.
Synthetic is the only oil Briggs recommends for any engine load at any temperature.
[Reply]  [No Email]
LOU from Wi.
10-25-2012 21:02:46
72.160.225.99
 Re: What A joke W/Pix in reply to Jon Hagen, 10-25-2012 20:58:09
Jon Hagen, Thanks, but we are using synthetic, no trouble with the valves, the pushrod that operates the valve came out of the lifter,causing the valve cover hose to push oil thru the hose into the carb.Sorta looked like he was fogging for bugs while he was vacuuming leaves.lol
Lou
[Reply]  [No Email]
Jon Hagen
10-25-2012 21:17:22
69.26.17.61
 Re: What A joke W/Pix in reply to LOU from Wi., 10-25-2012 21:02:46
Good your using synthetic oil in that engine.
Also make sure the cold valve setting is not more than .005. The valves get loose on those motors which can deactivate the compression release making for hard cranking / pull rope kickback.
Also make sure the rocker studs are tight in the head. On occasion a rocker stud will back out of the head and loosen the valve gear to the point the pushrods drop out.
[Reply]  [No Email]
LOU from Wi.
10-25-2012 21:20:04
72.160.225.99
 Re: What A joke W/Pix in reply to Jon Hagen, 10-25-2012 21:17:22
Jon Hagen, Thanks for the information, it's nice to know.So far there was no kickback on the rope,but will double check the settings.
LOU
[Reply]  [No Email]
huntingreen2day
10-25-2012 20:45:40
75.131.120.19
Well if you are not going to use an OVH engine you must be going to put an older one on then. Don't know of anyone building new flat heads.
[Reply]  [No Email]
LOU from Wi.
10-25-2012 21:07:20
72.160.225.99
 Re: What A joke W/Pix in reply to huntingreen2day, 10-25-2012 20:45:40
huntingreen2day,
If we can't find a standard valve configuation, by Briggs & Stratton, we will go to honda or kohler type engine.Hopefully we will luck out on one or the other.In my opinion, Briggs made a mistake with that type of application on that engine.Always liked Briggs until this one, especially the cast iron heads,last forever and very little mechanical trouble,may have to go to an older engine design. If so we'll rebuild it.Thanks,LOU
[Reply]  [No Email]
Jon Hagen
10-25-2012 23:30:02
69.26.17.61
 Re: What A joke W/Pix in reply to LOU from Wi., 10-25-2012 21:07:20
Briggs still makes some flathead engines.
I just bought a new low end Briggs & Stratton pressure washer which has the flathead 675 series engine on it. Their new "sure start " fuel system is impressive in how easily it starts.
Most of the time it is running about 1/2 way through the first pull.
You really should not be having problems with that OHV engine though, I have two older rider mowers with 15 hp OHV Briggs engines that have been very reliable.
Usually loss of valve seats out of the aluminum heads like s crum experienced is related to overheating from clogged cooling fins.
[Reply]  [No Email]
Brad Buchanan
10-25-2012 20:33:49
74.71.185.165
I don't know about the motor, Lou but that black box attached looks just a little bigger than my first apartment.
Regards,
Brad
[Reply]  [No Email]
LOU from Wi.
10-25-2012 20:35:50
72.160.225.99
 Re: What A joke W/Pix in reply to Brad Buchanan, 10-25-2012 20:33:49
Thats my bedroom, when the war dept (wife) gets mad at me.Small TV and an electric heater and army cot is my home.lol
LOU
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
