Tranny not up shifting
El Toro
I have a 1981 Mercury Cougar just started not upshifting. Is there a vacuum solenoid modulator used? It will up shift eventually and stays there until you slow down to a crawl or stop. It has that automatic overdrive, but I don't use that since it's too hilly and traffic is terrible. Hal
PS: It only has 56k miles. It has the 302cid engine.
(quoted from post at 19:17:51 10/18/12) I have a 1981 Mercury Cougar just started not upshifting. Is there a vacuum solenoid modulator used? It will up shift eventually and stays there until you slow down to a crawl or stop. It has that automatic overdrive, but I don't use that since it's too hilly and traffic is terrible. Hal
When I've run into that problem(
not that often) it has nearly always been modulater related.
It could be the C5 which is a modified C4 with a centrifugal converter clutch. Modulator would be a first guess then the fluid.
Hi Guy,
At the carburetor throttle, see if that TV control rod, which goes down to the transmission, is still connected. Oftentimes, those flimsy little clips will come off.
If it is still in place, go underneath the car to check the lower end, which connects to the 'inner' shaft of the manual shaft.
Allan
Thanks for all the replies. I had 2 other vehicles that had the same problem. It was always the modulator. The first was a 1959 Rambler Rebel wagon. Had to several shops and first said it needed the oil changed. It never helped. The Rambler shop said it was shifting normal and I told him it never took that long before. The owner of the Rambler had a son that taught auto shop at the local community college and I knew he was a first class mechanic.
He also raced Nash cars back in the late 1940's and 1950's on dirt tracks. The Fords always out ran the Nash. I ask him about the late
upshifting. He said it was the modulator. The same mechanic that told me it shifting normal replaced the modulator. That fixed the problem.
The other vehicle was a 1979 Chevy P/U. I found the vacuum line needed replacing to the modulator. I was a lot younger back then, when you're approaching 80 I don't like crawling around on that creeper. Hal
Oh for sure.
And 'sides that, you could be under there for days, weeks.......heck, even years trying to find that vacuum modulator.
You have the AOD transmission if it's an overdrive. They use a throttle valve in leau of a modulator valve.
See if that carb linkage is hooked up properly and we'll go from there.
Allan
