| Author |
[Modern View]
| DeltaRed
10-11-2012 07:00:27
67.6.219.50
Still got about 30 acres to go.These are small fields of about 2 to 6 acres-odd shaped at that.Second cut grass with a 'touch' of alfalfa.If the weather holds this will be the best hay of the season.I'm ready to be 'done'.Steve |
[Reply] [No Email] | |
| ihman73
10-12-2012 19:27:10
67.43.125.31
Re: Anyone still haying? in reply to DeltaRed, 10-11-2012 07:00:27
| Got my 5th cutting of alfalfa to cut yet and some waterways that have enough regrowth to cut again...If we can get enough dry days in a row to get it up. Working on beans now. Running around 40-45 bpa 12% and green stems. Looks like silage coming out the back of the combine. |
| Allen Goodman
10-11-2012 21:02:11
70.196.195.171
| The guy who leases the home place from us just cut the 6th cutting. That's right, 6 cuttings (alfafa) this year in and around Rocky Ford/LaJunta Colorado area. Everything is irrigated. Got water yesterday going over our wheat field I planted 2 weeks ago (4 inches high) and over the pastures. Topping off the pond with the run off tonight. |
| torwood9
10-11-2012 20:45:20
71.87.25.72
| Baling tomorrow, only a little bit, but its on the ground and people need hay in Central WI. Then we can park the baler. |
| Mo 1032D
10-11-2012 18:54:38
216.145.149.118
| Gonna try for second crop, got first cut done second week of may. Didn't get any rain after that, only grew back about 4 inches. Mid Mo got real dry along with a lot of other States. Even had guys trying to pass CRP hay as second cut brome, sad what people will do to try and make a buck. |
| samn40
10-11-2012 17:41:22
81.135.25.67
|  Finished for the season with 3rd cut grass on Tuesday, round baled and wrapped, 5 bales per acre this time...18 the first cut and 10 on the 2nd, cold and wet here this year, so growing was slow. had to use the old tractor as the others were busy behind the combine and hedgecutting..... Today we had 2 inches of the wet stuff... ground is totally waterlogged, tractor work may be finished for this year! Sam |
| Don-Wi
10-11-2012 16:55:08
75.207.170.159
| Not trying to cut anything anymore, but the 5th crop looks tall enough I might suggest to Dad that he starts green chopping it. Looks pretty good for this late in the year.
Donovan from Wisconsin |
| Leroy
10-11-2012 16:30:19
69.88.205.38
| Not mine. West central Ohio. Had to go for some business about 18 mile away. Saw 5 fields laying, comming back they were chopping the one. |
| TGIN
10-11-2012 15:37:38
4.252.94.148
| Got about 30 a. of grass to go . They keep throwin little showers at us but it is getting late , gona have to mow it and hope for the best . |
| Old Harv
10-11-2012 12:54:37
198.164.30.19
| I have about 30 acres I would like to do but it is snowing outside right now, and the 14 day weather forcast calls for rain 12 of the next 14 days. I will be happy to get my plowing done! |
| 4020deereboy
10-11-2012 12:27:11
205.185.95.11
| Just swathed the oats I drilled end of July and the peas and oats I drilled the first week of August should be ready to bale Ina couple days I'm surprised they made a crop since it has been to snow around here anytime after labor day |
| fullthrottle
10-11-2012 11:55:33
209.183.51.44
| I'm a little south of you in northern NM. Baling the last 30 acres today. Making small squares to sell over the winter. (I hope) Hopefully pick it up Saturday and be finished. |
| Dick2
10-11-2012 10:16:23
174.19.205.113
| They usually get 7-8 cuttings here on irrigated land in this part of AZ, but I heard that with the extreme heat that we had this summer they were only going to get 5-6 cuttings. |
| rrlund
10-11-2012 09:34:17
207.241.137.116
| Sure not me,but there was a custom operator cutting some horse hay yesterday right along where I was picking corn. Don't know if the owner even knew he was cutting. Temps are mid 50s,supposed to rain all weekend. Wouldn't think a horsey guy would appreciate that. |
| JayinNY
10-11-2012 09:18:56
166.137.88.151
| I prolly could make more second cutting, and definitely mulch hay, my friend called me 2 weeks ago looking for more mulch but the weather has not worked in my favor. I'm most likely done for this year! Last year columbus day it was 70 degrees and dry, this year 50 degrees and rainy, and damp! |
| Dave Sherburne NY
10-11-2012 16:53:11
50.48.61.229
Re: Anyone still haying? in reply to JayinNY, 10-11-2012 09:18:56
| If your friend wants big round mulch bales near Sherburne , Email me. |
| chevytaHOE5674
10-11-2012 08:58:31
74.221.56.19
| If I wanted to make hay this late in the season I'd have to rake the Snow off first. haha |
| TractormanNC
10-11-2012 08:56:30
108.72.58.200
| My last 12 acres is on the ground right now. Got washed last weekend. Hope it'll go by Saturday. |
| old
10-11-2012 08:21:54
209.86.226.34
| I'm thinking about trying to put some hay down next week if it stops raining long enough. The weather guessers are saying rain for the next 4 or 5 days. I know if I can bale 5 bales of hay I could sell 20. This area is hurting for hay so figure if all I get is 5 bales it is sure better then no bales |
| MoMike
10-11-2012 08:12:51
65.202.124.4
| South central MO here, have a rented place to put down yet. Waiting on the weather as they are calling for rain this weekend, hopefully cut in the next week or so. We realy need to get more hay up due to the drought. |
| Allan In NE
10-11-2012 08:11:59
148.66.98.174
| | I can remember putting up hay 2 years ago.... :>( Allan |
| WyoDave
10-11-2012 08:01:24
75.220.137.200
| | Got a couple hundred acres on the ground, and a couple hundred still to cut. Probably be stacking bales on Thanksgiving again this year... I just hope I'm done before the first of the year. Don't want to drag it out too long, ya know. David |
| cjd12000
10-11-2012 07:55:28
174.252.40.61
| Last loads went up silo yesterday will wrap more if I can finish corn before snow flies |
| Hogleg
10-11-2012 07:43:23
38.104.162.74
| Got 4 acres down, hope to roll today. Rain coming tomorrow but the grass is drying slooow...
Tell me about wrapped bales of grass. I have a 605H twine baler. How do you wrap them (by hand hopefully) and how do they cure, what can you feed?
John |
| low budget
10-11-2012 07:55:34
74.46.13.229
Re: Anyone still haying? in reply to Hogleg, 10-11-2012 07:43:23
| I have a Vermeer wrapper, actualy built by McHale. Individualy wrapped, still wet and makes silage out of it. If you are just trying to make a few they make bags (like a large garbage bag) that you can slip over a bale, get as as much air out as possible, (some people use a shop vac) and tie off. |
| rustyplow
10-11-2012 07:42:07
75.51.103.239
| Finished last saterday. 4 acres of alfalfa grass mix. Layed on the ground for week and a half. never realy did get dry but I baled it anyway. most will be alright. Some I had to open up. |
| donjr
10-11-2012 07:41:54
72.71.177.74
| About 50 acres to do yet.... |
| David G
10-11-2012 07:17:59
205.215.206.18
| Yes, have about 30 acres of grass hay to do yet. |
| low budget
10-11-2012 07:24:14
74.46.13.229
Re: Anyone still haying? in reply to David G, 10-11-2012 07:17:59
| Hasn't snowed here yet, so I'm still haying. Wrapped round bales. Central NY |
