Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: John Deere 301AG
[Return to Forum]
John Hempel
10-05-2012 15:10:01
67.177.83.138
I recently bought a used JD 301AG tractor and having some problems with the hydraulics. The "G" stands for gasoline and the engine seems to be okay.
The 3 point hitch is not working properly but we think the pump is okay. We've changed the oil and filter and cleaned a strainer on top of the pump. The level is showing high so we drained some oil out but no help. Is there any kind of control valve or another strainer that needs to be checked or adjusted?
[Reply]   [No Email]
geok
10-05-2012 17:39:38
24.249.3.44
 Re: John Deere 301AG in reply to John Hempel, 10-05-2012 15:10:01
If the 301 is similar to a 2040, there is a cylinder screen in the bottom of the tractor. There should be two plugs on either side that a 1/2 drive ratchet should fit into. The screen is between the plugs.
[Reply]  [No Email]
buickanddeere
10-05-2012 20:26:23
209.240.116.104
 Re: John Deere 301AG in reply to geok, 10-05-2012 17:39:38
Just like every 20,30,40,50 and 55 series Mannheim and Dubuque tractor.
[Reply]  [No Email]
LJD
10-05-2012 15:34:55
75.250.252.81
Put a 3000 PSI gauge into the pump's test port. See what the pressure is when not trying to use the hitch and then WHEN using the hitch. If you've got over 2000 PSI in both tests - your problem is in the hitch linkage.
301A is the industrial version of the 1020 ag tractor. I assume you've got the three-cylinder 135 cubic inch engine and the small German hydraulic pump.
[Reply]  [No Email]
buickanddeere
10-05-2012 15:27:57
209.240.116.104
The 301A would likely be similar to a 30 series tractor given it's a gasser but.......Who knows as Dubuque and Mannheim mixed and matched a lot of parts.
Guessing a gasser 2030 would be close to similar?
[Reply]  [No Email]
buickanddeere
10-05-2012 15:14:49
209.240.116.104
Measure the transmission oil system pressure, should be 150-165 when a pack is applied.
Is there a high-low shift or a reverser? The seals can fail in them after a few decades of service.
Or could be cracked lines, failed fitting or a stuck valve inside the transmission.
Front pump rarely fails unless exposed to dirty oil.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
