:B WIDE FRONT END FARMALL TRACTOR
Anonymous-0
I HAVE A fARNALL wIDE FRONT END TRACTOR ALL TAGS AND SER ## DEFINE THE TRACTOR AS A b mODIFIED SIMINLAR TO THE SUPER "a" THE TRACTOR DOES NOT HAVE 3 PT HITCH DOES HOWEVER HAVE PTO ON THE LEFT SIDE ONE SPLINE OUT THE REAR AND THE OTHER ON THE SAME GEAR BOX TO THE RIGHT SIDE FROM THE BACK: TRACTOR gURU SAYS THIS IS A b MOD ONLY 47 MADE DOES NAYONE HAVE DETAILS FOR VERTIFICATIONS
Serial tags could be right or wrong! was the seat bracket ever changed?
What are the lenghts of the rear axle tubes?
B would have 2 the same. A would have one long one short. A pictur would help. oldiron29
Never heard of a B Farmall with a wide front and as far as I have ever heard there never where any with a wide front but then a person can put parts from a A on a B or BN and make it have a wide front I know because I have what I call a BA which from the transmission forward is a B and from the transmission back an A so it is a BA so could well be you have a AB
i dont think he meant to have all caps. if you look at it the beginning of most of the important words are under case. therefore he must have accidenlty hit caps lock
Some people put the fronts from an A on Bs I know where theres two of them one cults his Rhubarb i built him a cult for the crop and the other works in the timber and war worried about upsetting. Your serial# on the block would start with letters FAB if its a B and if its an A the serail# would start with FAA. Serial# itself doesent identify as the next tractor down the line got the next # cause both models were built on the same assy line whether it was Chicago or in47 Louisville.
About a month ago there was a large antique tractor auction in wisconsin with some very rare tractors. I remember a farmall b with a wide front on the auction bill. It had shields on the front tire for cultivating some type of vegetable. It was probably some type of either special attachment, or supplied aftermarket. I will look and see if i still have the auction bill.
If it is a B with a wide front axle, it was modified after it left the factory. IHC did not offer a wide front axle for the B, only a single front or a dual tricycle front.
Harold Hu
