| Author |
[Modern View]
| 55 50 Ron
10-02-2012 19:56:59
209.131.224.44
I see a lot of use of the term "drag" for pull type implements.Always irks me a little to see that!! I prefer using the pull type description. Drag is such a drag!! |
| ramtuff
10-03-2012 16:08:22
98.93.2.204
Re: drag versus pull type in reply to 55 50 Ron, 10-02-2012 19:56:59
| Drag?
10-03-2012 10:10:05
198.53.25.107
| When you carry a man purse, it's a drag implement. |
| davida
10-03-2012 10:07:57
66.116.62.134
| | I think the tractor does the pulling and the implement did the dragging along the ground. But I could be wrong. |
| JOHNNYfromMI
10-03-2012 07:27:28
74.115.62.95
| Is that type equipment only used by people dressed "in drag"? |
| JMOR
10-03-2012 05:56:08
72.181.173.171
Re: drag versus pull type in reply to SweetFeet, 10-02-2012 19:56:59
| Quoting Removed, click Modern View to see
Somebody needs more troubles/things to worry about! All this time, I thought it was a term to describe the way 'funny-boys', like Barney Frank might dress at night. :roll: |
| jackinok
10-03-2012 05:46:54
162.58.82.136
| Here..with wheels- pull type. No wheels -drag type..UNLESS your SELLING,then their ALL pull type (theoreticaly worth more money). IF your BUYING of course they are all drag type,(since they are theoreticaly worth less). LOL |
| 55 50 Ron
10-02-2012 20:51:05
209.131.224.44
| | hardscrabble, I grew up in north central ND and your description is exactly as I remember for drags. I get the impression that today some use the term "drag" to mean non 3 point type implements. No one used 3 point implements in ND in the 40s and 50s when I was growing up so everything was pull type even the actual implement called a drag. |
| Leroy
10-03-2012 04:37:12
69.88.205.38
Re: drag versus pull type in reply to 55 50 Ron, 10-02-2012 20:51:05
| You are exactly why some use the term interchangably to designate between mounted equipment or non mounted and some will use that term to mean a pull type without wheels. I grew up in the area most machinery was the pull type, The 3 point for the Fergusom Implements was here but only the Ford And Ferguson tractors had it, Deere not yet. |
| onefarmer
10-02-2012 20:48:51
184.63.126.212
| Here a drag is a drag unless it has wheels then it's a wheel drag. |
| Will Herring
10-02-2012 20:33:23
50.103.227.28
| The only thing I ever recall being called a "drag" is a this giant flat things with horizontal blades that scrapes and levels the ground... Hmmm... |
| hardscrabble
10-02-2012 20:21:46
69.57.91.137
| Here in NW ND a "drag" is a spike- or tine-tooth harrow, regardless of whether it has wheels or not. |
| todd Hamilton
10-02-2012 20:16:48
174.252.150.235
| Old style disks without wheels were called drag disks. Also harrows without wheels were sometimes call drags. We used to pull a "drag" behind the disk to level the dirt. |
| Royse
10-02-2012 20:00:40
69.36.49.151
Re: drag versus pull type in reply to Paul Simmer, 10-02-2012 19:56:59
| Pull in transport position, drag when in use? |
