| Tractor Talk Discussion Forum |
Topic: ot washing machine
[Return to Forum]
| Author |
[Modern View]
| kornfused
10-02-2012 15:23:53
69.150.233.202
My wife uses this washer to clean my dirty clothes from working on the tractor so here the question. It won't spin dry the clothes. With nothing in it at all, it spins veeerrryyy slowly. Belt is not slipping, sounds like it wants to go but can't - time to replace? |
| FarmerZeb
10-03-2012 14:05:25
72.135.22.19
Re: ot washing machine in reply to kornfused, 10-02-2012 15:23:53
| | i'd fix it and keep it similar problem happened to ours last year 20 buck or so in parts and its good for another few years a new washer is expensive an a lot more expensive to fix with all the electronic control boards. -paul |
| NEBeef
10-03-2012 07:59:58
198.51.119.151
| I got my mother's dryer in pieces all over her laundry room floor. Started making a real racket, she said just go buy a new one. I said not until I figure out what's wrong. 20 minutes later I had a plastic drum type fan in my hand with a egg-shaped hub, $17.90 online + $7.00 shipping. Even if she only gets another year out if it for $25.00 and some of my time I figure it's worth it. But it's an older one so I figure chances are good it will now outlast what would have replaced it anyway... |
| hermit
10-03-2012 04:09:07
96.8.194.96
| If the washer has the extra rinse setting, try it on there and let it cycle all the way through and see if this helps. Mine won't spin out worth a dern on the regular setting, but if I put on the extra rinse it works fine. I have just left it there for several years. Yeah, that uses extra water and electricity, so if it was used very much I would fix it. Also another excuse for not fixing it is where it is-it is hell to get out of where it is wedged in. If that ain't enough, I have other excuses too! |
| Bendee
10-02-2012 19:40:59
121.219.171.65
| Seems its life expectancy has expired, help the Chinese economy and get another machine. Is it worth the fa^ting around?. |
| Fritz Maurer
10-02-2012 17:51:24
216.137.138.178
| If it is the machine Vern is describing, the pulley is forty bucks, the mating ramp-like clutch is about ten, and takes about two hours to put in. The job looks worse than it really is. It would be sort of wonderful if you could set it up on a bench a foot or so off the ground. Look at the driven pulley while it's trying to spin. If it's running off the end of the ramps, those are the two pieces you need. |
| VernMI
10-02-2012 16:56:10
209.86.226.18
| | Is it at top or front loader, Neptune or Atlantis? Is the water being comletely discharged so that the inner basket is free to spin? Maybe the pump is not completely discharging the water from between the drums. Is the pump belt snug enough? Does it run slow in both the wash and the spin cycles? Does the brake release when the inner basket is trying to spin. A common problem on this type of machine is the transmission drive pulley and thrust bearing kit. If the pulley ramps have worn down or the thrust bearing has worn out, the brake won't be releasing all the way causing the brake to drag and not letting it get up to full spin speed. Is there any clothing trapped between the inner and outer tubs. Check that the motor slides back and forth real easy and smooth, clean the motor plate and nylon slide and put a light coat of oil on the plate where the nylon slide rides, make sure the motor tension spring is still in place. It could be a be a problem with the transmission leaking oil. The shaft seal on the transmission could leak oil and it could get on the clutch. The clutch pads that are supposed to grab and turn the tub could be covered with oil. When the clutch pads get oil on them it makes the clutch slip too much and you never achieve full spin speed. Any sign of oil leaks under the machine? |
| patsdeere
10-02-2012 15:25:48
64.166.144.11
| Sounds like the tranny died. Probably time to look for one on craigslist. No point in wasting good money on a new one. |
| kornfused
10-02-2012 15:30:53
69.150.233.202
Re: ot washing machine in reply to patsdeere, 10-02-2012 15:25:48
| that would be the 2nd tranny in about 14 years. Maytag ain't what they used to be. Last time the tranny went out is was a horrendous squeel and knocking. It was less than 10 years old so they gave me a new one - but not it is out of warranty. |
| Dave in Tx
10-02-2012 16:36:58
166.147.72.27
Re: ot washing machine in reply to kornfused, 10-02-2012 15:30:53
| That figures out to about 2.21 cents per load. I wouldn't have one of those junkie things, LOL. Fourteen years ain't bad. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
