| Author |
[Modern View]
| DannyH in NE Kansas
09-30-2012 18:04:05
64.6.122.12
Do the 1991s have the same issue with the timing gears that the older ones do? I've had 4 1970s and 1980s 302s/351Ws that all needed the timing set replaced due to the nylon coating coming off. |
| brian brooks
10-01-2012 02:50:19
173.17.71.242
Re: F150 with 302 engine in reply to DannyH in NE Kansas, 09-30-2012 18:04:05
| In the late 80s they went back to the all steel3 piece timing set |
| NEKS
09-30-2012 20:31:59
71.0.221.163
| Had a 74 club wagon van with 302 and never had any problems with timing gears. |
| big fred
09-30-2012 20:17:49
174.21.94.149
| The 302 in my 95 F-150 was going strong at 247K miles when the tranny went south and I sold it to a wrecking yard. Engine didn't miss a beat in that time except when the O2 sensor needed replacing near the end of that time. |
| Lumpy
09-30-2012 19:55:52
208.126.151.224
| Yep! They never fixed that problem. |
| GVSII
10-01-2012 15:25:28
74.71.178.71
Re: F150 with 302 engine in reply to Lumpy, 09-30-2012 19:55:52
| I've put a pile of miles on "302's" in many pickups and cars and even one boat. Never lost a timeing set. But I did change oil/filter often. |
| rla
10-01-2012 06:02:16
162.39.22.109
| Ford's new parts are a double roller chain & all steel. Timing chains LOVE clean oil. The customers I've had over the Years ( 37 ) who changed engine oil @ 3000 miles Never had timing chain & gear issues. The folks who 5K to 7500 miles would need a new chain at 90,000 to 100000 miles.. For those of you who say OIL is better now & shouldn't be changed @ 3000 miles, when it come's to timing chains I disagree... I feel the same is more of a issue today with all these over head came engines with 2 or more chains. |
| DannyH from NE Kansas
10-01-2012 06:46:45
24.248.193.103
Re: F150 with 302 engine in reply to rla, 10-01-2012 06:02:16
| | I also agree on 3k oil changes on engines with more than one timing chain. Usually those rely upon hydraulic chain tensioners to keep the timing chain tight. The dirtier the oil the less tension the hydraulic tensioner can apply, the looser the chain the more wear it causes. Ask Chrysler and Toyota about that. |
10-01-2012 06:42:45
24.248.193.103
| | I know the replacement part is all steel (seems like it always has been), but is the original gear set on a 1991 the nylon coated POS? I agree with the oil changes at 3K miles, for the cost its just cheap insurance - especially on older carbed engines and throttle body fuel injection. |
| rla
10-01-2012 08:29:13
162.39.22.109
Re: F150 with 302 engine in reply to DannyH from NE Kansas, 10-01-2012 06:42:45
| It might have been in 91? Back alott of years & the parts Book doesn't really say? I thought in the car line they went to all still in 1990 But now all the # have been updated to dual roller chain?? So I guess?? If it has a single older style chain it could very well have the plastic coated gear on the cam.... |
10-01-2012 08:50:15
24.248.193.103
Re: F150 with 302 engine in reply to rla, 10-01-2012 08:29:13
| | So basically I need to open it up. I'm getting the occassional miss at extremely slow idle that makes me think the timing chain has some slack in it. Runs great at higher RPMs with centrifugal force taking the slack out of it - just like all the others. Everyone of them would eventually get worse until it jumped time or had some other issue that popped up. Any way to check this without tearing into it? |
| mite-help
10-01-2012 09:36:36
70.196.3.112
Re: F150 with 302 engine in reply to DannyH from NE Kansas, 10-01-2012 08:50:15
| yes, it can be checked somewhat by turning crank-pully back/forth-you can pretty much feel when cam catches up--usually a bunch of degrees on worn chain-- |
| rla
10-01-2012 11:12:44
162.39.22.109
Re: F150 with 302 engine in reply to mite-help, 10-01-2012 09:36:36
| Yes What MITE HELP suggest's would tell you alott..... On How much Slop the chain has... Make sure you check the Pickup coil the module plugs into. |
