OT: do you make stuffed banana or jalepeno peppers? How
redtom
Every year i throw out lots of banana peppers. I bought some raw breakfast sausage to try stuffing them with and grilling. How do i do it? Will the meat get done before the peppers get grilled/scorched. Should I use some sort of precooked or smoked sausage instead? Just cut them into little "boats" and fill right?
I've done an alternative to the traditional meat-loaf style stuffing with great success. I use the whole pepper (bell peppers), hollowing it out through the top where the stem goes in. I use either hamburger or chicken (pre-cooked) and mix it with various flavors of rice-a-roni. I use lots of cheese, and sometimes chopped nuts like pecans or macademia nuts. Mix it all into a mush and pack the peppers full. The way I do it makes 6-12 peppers depending on size. I freeze a lot of them and eat them through the winter. About 45 min- 1hr at 425 in a casserole dish and they're not too bad.
For jalapenos, cut them in half, take out the seeds and fill them with a mixture of cream cheese & tuna fish. 400 degrees in an open pan for 20 minutes and they are yummy. I usually put in a little cheese, too. My brother likes them with parmesan sprinkled on top.
redtom,
For grilling (or baking) stuffed peppers, I fill with raw meat & rice, chopped onion and a dab of ketchup and seasonings all mixed together - the raw meat juices add a nice flavor compared to precooked meat. Then I cook them in a cake pan covered with tinfoil via indirect heat on grill. Once the meat mixture is done and the peppers are fairly tender, then I put them on the grill grate for a bit to brown them and give them that nice smoked flavor.
I actually do my BBQ ribs the same way: rubbed with seasoning, cooked in apple juice and chopped onion in a covered pan until tender. Then I put them over low fire to brown them and baste with BBQ a couple times on each side.
Big peppers I split one side length wise, remove the core. Fill with sausage, onions, and cheese. I loosely wrap them back up in tin foil with just a little oil in foil. Grille over low heat until the sausage is done and eat.
You can stuff them with whatever you please.
Rick
My son-in-laws Grandfather used to cook a lot of them. Take the jalapenos, cut the top off, clean the pepper seeds out, fill with cream cheese- wrap with bacon.
He also made a cooker with big washers welded together and put some legs to keep the peppers off the grill. Have to put a toothpick thru them to keep them from flling thru. The son-inlaw, his dad, and his grandfather had several cookers like that that was the size of the grill --- cook 50-60 at a time. We used a jerky shooter to fill the peppers. Much easier than a spoon
I do a salsa/cheese mix in both types of peppers and how I do it is this. I mix cheese like the Valveta and home made salsa then still hot pour it into the peppers then bake them. I try to use bowl so that I can stand the peppers up to hold the cheese mix in. Did some habinoro (sp) for the son not long ago the same way and he loved them
