| Author |
[Modern View]
| Massey
09-10-2012 16:02:34
86.40.187.233
will the copper pipe between the injector pump and the injector be strong enough for the pressure. |
| 504
09-10-2012 19:33:41
64.111.61.44
Re: copper pipes in reply to Massey, 09-10-2012 16:02:34
| Copper may take the pressure but will not take the vibration of the fuel, I would give it two hours before it breaks at the flair. BTDT |
| Justin SE IOWA
09-10-2012 19:20:31
166.182.3.93
| I dont know what kinda pressure your talking but my Allis WD has 3/8 copper for the hydraulic lines and it runs at 3800psi. They have been like that for years and no problems. I say go for it. |
| old
09-10-2012 19:19:01
209.86.226.19
| No trouble waiting to happen. Now if you used brake line that would work and it is cheap as in a buck or so a foot |
| pete 23
09-10-2012 19:10:14
74.32.238.2
| Another thing to take into consideration. All injection lines have a very specific size hole in them. It match's the retraction value of the delivery valve in volume. You never even want to install lines of different size inside holes let alone a copper line. It is not unusual for a manufacturer of engines to use different sized holes in the lines for same displacement engines as they change horse power, like adding a turbo etc. The delivery valve, injection nozzle and line all work together to cut off injected fuel with out dribble and still keep line full for next injection cycle. |
| jm.
09-10-2012 18:31:45
75.105.64.53
| Cut open your bad steel line and loosk and see how thick the walls are and you will forget about trying to use coper. Get the RIGHT line or you will be asking for trouble. |
| Bob M
09-10-2012 16:18:20
74.67.190.208
| | Don't even THINK about using copper! Copper pipe/tubing is subject to metal fatigue/rupture under repetitive high pressure fluctuations. Consequently it must not be used for diesel injection lines. |
| john730d
09-10-2012 16:13:31
208.73.228.5
| NO NO NO!!!!! You will get hurt bad. The lines from the pump to the injectors are also the same lenght, no matter which cylinder it goes to. It won't run right with different lenghts of tubing. |
| thurlow
09-10-2012 16:17:11
74.177.47.147
Re: copper pipes in reply to john730d, 09-10-2012 16:13:31
| The lines are all the same length???? |
| jon f mn
09-10-2012 17:02:24
8.10.223.145
Re: copper pipes in reply to thurlow, 09-10-2012 16:17:11
| Yes they all have to be the same length. That is why they have all the bends in them. |
| petetx
09-10-2012 16:04:26
76.1.74.121
| No please don't that is a good way to get hurt. |
