| Author |
[Modern View]
| Richard G.
09-10-2012 07:12:04
98.84.70.45
  Picked this up at the Somerset Steam and Gas show over the weekend in VA. Came with a belt driven pump. It has a partial sticker on it with a yellow picture of a hydraulic cylinder with a horse head and tail on it. Cannot read the name. Any idea what make it is? I want to put it on my 51 VAC Case as my shoulders are making it harder to steer. I do have room to put it in the steering shaft and will drive the pump off a double pulley on the alternator. Thanks for any info. Only paid $40 for it and the pump.
Richard in NW SC |
| mkirsch
09-10-2012 15:04:09
67.253.161.186
Re: Add on power steering unit in reply to Richard G., 09-10-2012 07:12:04
| glennster, could I bother you for a copy of those manuals too? |
| glennster
09-11-2012 05:48:32
75.57.143.173
Re: Add on power steering unit in reply to mkirsch, 09-10-2012 15:04:09
| shoot me an email, i can send the char lynn manuals to ya. i had them scanned as jpeg files, then a fellow yt'r converted them to pdf files for me. there is the installation, service, troubleshooting and parts diagrams for both the power steering pump and the torque generator. |
| Mike (WA)
09-11-2012 08:18:25
69.10.199.107
Re: Add on power steering unit in reply to glennster, 09-11-2012 05:48:32
| | I'd appreciate a set, also, if you could. email is mmittge at compprime dot com. Thanks! |
| glennster
09-11-2012 08:33:21
75.57.143.173
Re: Add on power steering unit in reply to Mike (WA), 09-11-2012 08:18:25
| glennster
09-10-2012 12:50:16
75.57.143.173
| richard, i sent you an email, i can send you copies of the manuals for the unit. |
| Richard G.
09-10-2012 17:21:27
74.177.120.131
Re: Add on power steering unit in reply to glennster, 09-10-2012 12:50:16
| Glenn, I tried to email you back but it did not work. Send me the message again and I will try again. Richard |
| greygoat
09-10-2012 10:40:08
184.158.58.98
| There should be a model number stamped into it. |
| Walt Davies
09-10-2012 09:34:30
174.255.162.108
| I have one on my Cochshutt 35 it works great. Can steer it with one finger. They cost about $3500 just for the motor add pump and hoses and you can by another tractor. Walt |
| Mike (WA)
09-10-2012 10:21:44
69.10.199.107
Re: Add on power steering unit in reply to Walt Davies, 09-10-2012 09:34:30
| | That's a little rich on the price of a torque generator- I just googled it, and Surplus has them for $505- another outfit has them for $499. And you could use any junk yard automobile power steering pump, for less than 50 bucks. They do work great- I also have a Cockshutt 35 that I plan to put one on. |
| Allan In NE
09-10-2012 07:47:01
148.66.98.174
| | Charlynn torque generator. Allan |
| Richard G.
09-10-2012 08:08:26
98.84.70.45
Re: Add on power steering unit in reply to Allan In NE, 09-10-2012 07:47:01
| Thanks Allen. Just came in from the shop and in the daylight, I could see "Char" on the tag. I feel good about it now. Any problems I should look for? I will try it on low pressure before I go to the trouble of cutting the shaft on the tractor. How do I know which end goes toward the steering wheel? Richard |
| Allan In NE
09-10-2012 08:45:07
148.66.98.174
Re: Add on power steering unit in reply to Richard G., 09-10-2012 08:08:26
| | The end with the hose manifold goes to the steering wheel. Allan |
| Richard G.
09-10-2012 09:03:03
98.84.70.45
Re: Add on power steering unit in reply to Allan In NE, 09-10-2012 08:45:07
