Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Calling James Howell
[Return to Forum]
kruser
09-08-2012 17:33:41
70.194.69.218
Molly and I went for a tractor ride tonight AND she needs HELP!
Don't know much about them old Jack Sheeps - But guess we got the hub to move!
James2
[Reply]   [No Email]
toolz
09-09-2012 17:04:33
206.221.154.149
 Re: Calling James Howell in reply to kruser, 09-08-2012 17:33:41
Travis M's, dad told me about your misfortune today- Me thinks the Ollie got jealous and loosened the axle bolts when you weren't looking. That'll teach you to mess with the "other green"! Glad Molly's ok.
[Reply]  [No Email]
Billy Shafer
09-09-2012 08:42:30
173.184.64.142
Were you in Centerville in the last two weeks.Saw an Oliver on a trailer that looked just like yours. Very nice tractor.
Glad Molly is ok. That would shake anybody up.
[Reply]  [No Email]
Nancy Howell
09-09-2012 08:37:43
75.254.4.122
Soooo glad she's ok & doesn't look like there's damage to the tractor, but big thing is she's ok.
BTDT, almost. My 48A is set up for spraying. I was spraying our hay field and the tractor quit moving. Thought the tranny had given it up. Pulled the clutch back, shifted gears and heard a "thunk, thunk, thunk". Started looking around and the left wheel had worked its way off the axle. The axle was resting by maybe 1/4 of an inch on the edge of the rim where the hub slides on the axle. The "thunking" noise was caused by the splines on the axle as it rotated on the edge of the rim when I engaged the clutch.
I very gingerly got off the tractor and shut it down. Walked back to the house and got James. We went back to the field with blocks, jacks & tools and remounted the tire.
Make it a point to look and see if the wheels have worked out any. Check the bolts periodically, too.
Its never happened again.
Interesting that it was the left wheel on my tractor, too. Also interesting that these wheels can be a huge pain to move in or out, but occasionally will work themselves off.
Sooo glad she's ok.
[Reply]  [No Email]
James Howell
09-09-2012 06:30:03
75.227.135.133
Hope Molly was not hurt from the fall and that she is OK.
Had to be a bone-jarring landing.
Very sorry that she had that happen to her.
I'd still be cussing looking around for a FOR SALE sign.
Here's what I'd suggest on getting her 52A road worthy.
Start by locking the right brake.
Put blocks in front of the right tire and front tires before you lift the tractor.
Photobucket
You'll need a couple more blocks to put under the drawbar.
Call glennster and get him to bring his tractor with the front end loader.
Once you get her 52A blocked up, check the splines on the end of the axle for any damage.
Photobucket
Put a chain through the "notch" between the wheel and rim.
Photobucket
Lift the wheel, rim, and tire with the FEL and press against the splines on the axle.
Turn the left brake drum by hand to line up the splines on the axle with the hub on the wheel.
Here's a couple of photos of the collar and hub on our 52A.
Photobucket
Photobucket
Hope this helps and sorry Molly had this happen.
[Reply]  [No Email]
Old Roy
09-08-2012 19:50:34
71.206.209.119
Glad no one hurt . One ride that won't be forgotten soon .
[Reply]  [No Email]
37Chief
09-08-2012 19:21:45
68.8.206.100
Hate to see that happen, glad no one was hurt. I had the axle pull out of the final drive on my JD 5020. Had to have the tractor hauled back home. I didn't make much on that job. Stan
[Reply]  [No Email]
wisbaker
09-08-2012 19:14:53
207.118.150.106
So next time someones on the JD board asking how to get their wheels to move we'll just give 'em your name and you can show 'em ho it's done!!
[Reply]  [No Email]
Fixerupper
09-08-2012 18:29:05
100.42.82.164
That happened to our 51 A when dad was planting corn with it. He came walking home and calmly told me the A lost a wheel. I went out there with the loader, picked up the A, slid the wheel back on and went back to planting. About every round I checked the bolts till I was reasonably sure they were TIGHT!.
The neighbor lost a wheel on their 4020 while going down the blacktop road. There was a gouge in the road in that spot till they resurfaced it several years later. Jim
[Reply]  [No Email]
kyplowboy
09-09-2012 07:52:20
98.93.15.67
 Re: Calling James Howell in reply to Fixerupper, 09-08-2012 18:29:05
Neigbor lost both duals off the right side of a 4440 several years ago go'n down the road, axle broke off right next to the rear end. There was a bump in the road till they paved it a few years ago. The yard he was in when he got stopped lost a few small trees in the deal.
[Reply]  [No Email]
Armand Tatro
09-08-2012 18:23:17
98.227.26.140
When we broke the right rear axel on the Farmal 400 we had a 2MHD mounted picker on it picking corn proably in 2nd. gear. Never did find the first two 3X12 planks that we were using as a foundation for the 8 ton hyd. jack. We replaced the axel in the field where she broke. Armand
[Reply]  [No Email]
J.Wondergem
09-08-2012 18:09:43
70.194.9.169
 Re: Calling James Howell in reply to Tony in Mass., 09-08-2012 17:33:41
Is that a little brown spot in the middle of the seat of the JD?
[Reply]  [No Email]
Royse
09-08-2012 17:57:29
69.36.49.151
That happened on our JD50 once. Jacked it up, put it back on, never missed a lick.
Does make for an interesting ride tho!
[Reply]  [No Email]
BushogPapa
09-08-2012 18:23:17
173.88.51.117
 Re: Calling James Howell in reply to Royse, 09-08-2012 17:57:29
Axle break..???
Over the years, we have broken 3 axles on our Late Styled "B"..always with the #226 Corn Picker..
They would break right outside the bearing..right where the splines end..
Ron..
[Reply]  [No Email]
donjr
09-08-2012 17:54:34
71.248.83.169
BTDT- see 'Bad Day' below---
[Reply]  [No Email]
kruser
09-08-2012 17:42:08
70.194.69.218
PS: Said she was going to take a shower now!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
