Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: staybul for ethanol
[Return to Forum]
mkirsch
08-31-2012 10:07:11
64.80.110.75
Water does not mix with gasoline. It will sit in a glob on the bottom of the gas tank and get sucked into the engine all at once.
Water mixes with alcohol.
Alcohol mixes with gasoline.
The water is "removed" when it is sucked into the engine along with the gasoline and alcohol, and goes out the exhaust as steam. Since it's mixed with the alcohol and gasoline now, the water goes through in small enough amounts that it does not cause problems.
[Reply]   [No Email]
Russ from MN
08-31-2012 10:21:05
68.235.89.1
 Re: staybul for ethanol in reply to mkirsch, 08-31-2012 10:07:11
Good explanation! I think it's fine at 10% or less
in equipment that is compatible with it. I do avoid
using it in fuel that I mix for two-stroke engines.
We used to buy a different kind of heet for our
snowmobiles, but haven't done that for 30 years.
[Reply]  [No Email]
paul
08-31-2012 12:55:43
76.77.196.99
 Re: staybul for ethanol in reply to Russ from MN, 08-31-2012 10:21:05
In modern cars - 2000 or so and newer - it appears a 15-25% ethnol blend is actually the most efficient. Considering the octane, stablity of the fuel, even flash point, and so forth, many modern engines will become more efficient at that blend rate, and offer the best bang for the buck in fuel usage.
That might seem counter intuitive to some, as ethanol has less BTU per gallon. But the deal is, it burns more efficiently _if_ the engine can be tuned to use that efficiency. Modern computers can monitor and use the good atributes of ethanol, and thus would do better with around a 20% blend.
Unfortunately, it's not legal to sell a 20% blend in a common fuel pump, so few people get to see this, unless they do their own blending using an e85 pump and a calculator.
I understand this does not apply to small engines or old carb engines, etc.
--->Paul
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
