Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: voltage
[Return to Forum]
gene zick
08-29-2012 19:31:14
4.245.76.57
I have a 1949 TO20 Ferguson tractor. It has been changed from a generator to an Alternator. Does this make it a 12 volt?
[Reply]   [No Email]
John T
08-30-2012 04:53:07
216.249.82.117
Re: voltage in reply to gene zick, 08-29-2012 19:31:14
Hopefully whatever alternator it is corresponds to the battery voltage and polarity???
If theres no battery as posted below theres a decent chance the alternator is for 12 volts NEGATIVE GROUND as thats the more common, HOWEVER it may be 6 or 12 volts and Pos or Neg ground, we just cant say sitting here.....
John T
  [Reply]  [No Email]
JMOR
08-29-2012 20:18:44
72.181.173.171
Re: voltage in reply to John T, 08-29-2012 19:31:14
Those alternators can even be made Positive ground!
  [Reply]  [No Email]
John B.
08-29-2012 20:15:25
38.114.64.185
Have it tested. Just because an alternator has been installed does not necessarily make it 12 volts. I took a 12 volt alternator and put in a 6 volt regulator. There is no external evidence on the alternator to indicate this. By having it tested at your local parts house will tell right away when it puts out it's regulated voltage. I hope this helps.
  [Reply]  [No Email]
oldtanker
08-29-2012 20:07:58
66.228.255.239
Eay way to find out. Call around to local parts places. Many have a bench tester and can test the alternator which will both tell you voltage and if it's any good. Most places bench test for free.
Rick
  [Reply]  [No Email]
Owen Aaland
08-29-2012 19:40:07
216.47.32.166
The 10SI alternator can easily be built to handle 6, 12, or 24 volt, either positive or negative ground.
  [Reply]  [No Email]
d beatty
08-29-2012 19:41:01
24.12.128.253
Does it have a 6 or 12 volt battery in it ? They do make alternators in 6 and 12 volt. What voltage battery you have in it will tell what system you have in it.
  [Reply]  [No Email]
Jon Hagen
08-29-2012 19:38:27
69.26.17.61
Generally yes, but I see Delco SI series, 1 wire alternators converted to 6V in the JC Whitney catalog.
You might get a little more info if 6 or 12V from any light bulbs, does it have a 12V coil or has an ignition ballast resistor been installed.
The tractor came without a battery I assume ??
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
