Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Questions on well pump
[Return to Forum]
Tinkerer05
08-29-2012 11:24:14
71.76.160.92
I have a two wire well pump at approx. 385ft. There is a Pressure Tank and a Pressure Switch (40/60).
With power off, I measure:
• 4.8 ohms between the two wires going to the pump (manufacturer’s winding resistance spec says 3.2 – 3.8 ohms, plus cable resistance from the well head to the pump
• On the pump, open circuit between each wire and ground
With power on, at the well head I measure:
• 235 VAC
• 6.2 Amps on each of the wires (manufacturer’s spec for the current: full load - 6.8 Amps, Max load – 8 Amps)
My problem is that I am not getting any water coming out of the well, after 10 years of good service. Since the readings all seem to be normal (I think) for the pump, it seems that the only conclusion I can reach is that the well has gone dry. Are there any other possibilities?
What should the psi be in the Pressure Tank with power off? I measure 10 psi. Is that reasonable?
Thanks!
[Reply]   [No Email]
oldtanker
08-29-2012 22:21:09
66.228.255.239
 Re: Questions on well pump in reply to Tinkerer05, 08-29-2012 11:24:14
Boy makes me glad that my well is only 12 Feet!
Rick
[Reply]  [No Email]
Tinkerer05
08-29-2012 16:06:36
71.76.160.92
Well, the digger just left - of all the responses, you got closest - the pump shaft is broken and the tank is bad. The only good news was that the motor was ok.
I guess 10 psi was the indicator on the tank since apparently it should have been around at least 38 psi. The digger reckoned that sometimes a bad tank can cause enough back pressure that it strains the pump but he also says its hard to tell. It could also have been a bad shaft.
The tank, pump and motor were all replaced about 5 years ago, so there's no warranty to fall back on.
So we are now pumping $1,700 back into the economy...
Thank y'all for your responses - great community - great forum!
I've reposted my earlier second message since I posted to the wrong spot earlier. But thanks again everyone for responding.
[Reply]  [No Email]
George Marsh
08-29-2012 13:44:23
50.104.200.175
The guy that drilled my well had a wood weight on the end of a tape. He measured how far the water was below grade.
You can only generate 10 psi at tank, right? I would think if your well is going dry, you would be sucking air. Any air bubbles?
I'm too old to pull a 385 ft well, so I would call my well guy out.
This could be risky. Attach a flashlight to a fishing pole. Lower the light and take a look see. I would use a small LED light and perhaps attach some wood to it in case the line breaks. That way I could go fishing for light.
I heard of a guy who's pump came unscrewed from the pipe.
Did your problem happen all at once? If it was slow in coming, I would bleach the well. Bleach removes iron, so if you have an iron well casing bleach it. Was told wells should be bleached every 6 month to a year.
Really all we can do is guess at problem. LOL
Let us know what you find out.
George
[Reply]  [No Email]
Old Magnet
08-29-2012 13:33:08
76.254.41.114
With those amperage readings it appears the pump is still moving water but not making enough pressure to discharge into your pressure tank.
Pressure tank should sit at the low pressure cut-in pressure (40psi) unless something is open that drains it down when the power is off.
Could be low water level in well, worn out pump or problem with discharge line.
[Reply]  [No Email]
Greenday
08-29-2012 12:37:44
204.185.166.6
Coupler or splines on shaft bad. Could be that the motor runs but pump end isnt.
[Reply]  [No Email]
Tinkerer05
08-29-2012 13:18:55
71.76.160.92
 Re: Questions on well pump in reply to Greenday, 08-29-2012 12:37:44
[Reply]  [No Email]
carogator
08-29-2012 12:25:45
64.12.116.74
two (2) pounds less than the cut on pressure. this is with all pressure off the supply lines.
[Reply]  [No Email]
DH in Carolina
08-29-2012 12:14:26
173.212.9.211
Intake screen on pump clogged.
[Reply]  [No Email]
grandpappy
08-29-2012 11:46:47
69.207.116.180
bad foot valve
[Reply]  [No Email]
Walt Davies
08-29-2012 12:23:42
70.199.132.3
 Re: Questions on well pump in reply to grandpappy, 08-29-2012 11:46:47
No foot valve on a submersible pump it already in the water.
Walt
[Reply]  [No Email]
Janicholson
08-29-2012 20:57:39
96.24.99.126
 Re: Questions on well pump in reply to Walt Davies, 08-29-2012 12:23:42
With respect, even though the pump is primed, it must be filled with water. There is certainly a foot valve on a submersible pump. The water would flow down the pipe and seek the well level. then when started the water hammer would be drastic if not dangerous. That stem pipe must be filled at all times. We use a valve on the open well stem and open it slowly to allow the stem to fill, then hook it up to the tank before finishing the task. Jim
[Reply]  [No Email]
Walt Davies
08-29-2012 11:45:42
70.199.128.69
It's time to call the well digger to come out pull the top off and inspect the pump system and well. It could be anything from bad pump to bad pipe to no water but you have to look in the well to tell which it is.
At 385 ft you can't pull the pump yourself.
Walt
[Reply]  [No Email]
Janicholson
08-29-2012 12:13:17
199.17.6.249
 Re: Questions on well pump in reply to Walt Davies, 08-29-2012 11:45:42
Walt is correct, The pile of 20 foot pipes will amaze you. The motor could be working but not connected to the impeller stack, the water could be below the intake, or the Impellers could be stripped on the splines. My stack of 9 impellers (450' water in a 500' well) was damaged (siezed to the stators) by operating momentarily in a bubble of natural gas. They siezed and stuck the motor. Best of luck, do not run it not working, it will be many more dollars. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
