Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: farm truck problem continued
[Return to Forum]
Codie
08-26-2012 13:25:53
70.15.67.38
My 95 chevy K1500 with 350 is still running rough once warm. New plugs, wires, cap, rotor, fuel and air filter along with colant temp sensor. It only acts up once its warm it runs fine cold. Im really lost, any other ideas?
[Reply]   [No Email]
Briar Hill Brittanys
08-26-2012 21:31:56
207.254.163.44
 Re: farm truck problem continued in reply to Codie, 08-26-2012 13:25:53
Had the same problem with mine, 95 K1500 TBI 350. Started and ran great when cold. Once it warmed up, coughed, sputtered, died at stoplights, inhaled fuel, hard starting when warm. After awhile it finally kicked a code for a bad coolant temp sensor. Replaced, and the problem went away for a week or so. Tracked back to the coolant temp sensor. Ended up being the wire running to the sensor had a bad spot in it. Replaced the damaged section, is running fine again. Old Blue has 240,000 one owner miles. HTH Mark
[Reply]  [No Email]
ghostown
08-26-2012 19:53:20
67.142.130.24
Had a similar problem with a 92 F-150. Drove me crazy, made an appointment with the dealer, couldn't get it in for a week so I gave it one last shot. Started checking voltages at sensors when hot and they were above 15 volts. Battery had a weak cell when hot, good enough to start the truck but opened up with alternator charging. Replaced the battery and everything was fine, canceled the dealer appointment.
[Reply]  [No Email]
gbs
08-26-2012 19:34:41
71.51.250.50
check the egr valve it could be stuck,check the tbi gasket they will crack and shrink,check vacuum lines for leaks
[Reply]  [No Email]
Centex Farmall
08-26-2012 19:21:35
166.147.72.28
Has the fuel pump in the tank ever been replaced?
One of the big box stores should have a "loner" fuel pressure test setup you can borrow.
[Reply]  [No Email]
toadady
08-26-2012 18:24:02
174.125.34.217
i work in a parts store, and i have seen MANY of these distrubitors wear in the housing making the shaft wobble, causing lots of problems, pull it out and see it should have little to NO slack in the shaft, a little up and down is normal
[Reply]  [No Email]
James Williams
08-26-2012 18:14:11
69.251.26.114
Unplug your EGR valve and see if it makes a difference
jimmy
[Reply]  [No Email]
Codie
08-26-2012 18:07:16
70.15.67.38
Ok thanks for all the ideas. Its a TBI motor. There is no mass air flow sensor on it. Its currently throwing no codes. I changed the oxygen sensor tonight. There is no catalytic converter on it any more and a glass pack muffler so exhaust flow shouldnt be a problem. No smoke in the exhaust either. So Im thinking vaccum leak or distributor/ spark maybe? I did also change the coil. Thanks for the replies. Any more ideas now?
[Reply]  [No Email]
barnE
08-26-2012 17:27:51
67.172.83.183
Oxy sensor could fail like some I have seen and give too rich mixture. Cold engine too rich would be OK. But after warming up it would be like the choke still on and flood. Look at exhause for lots of black smoke and carbon. Hope this is your situation. Dave
[Reply]  [No Email]
Brad Buchanan
08-26-2012 16:30:38
74.71.185.165
some of the earlier gm electronic distribtors would flub up when hot and the problem was there is an electronic module with four terminals that would overheat if replaced and not bedded in dialectric grease.
Brad
[Reply]  [No Email]
charlie n
08-26-2012 16:10:38
96.35.9.190
I had the same problem with a 99 5.7 Vortec.I did everything that the others mentioned with no success.Even change the fuel pump TWICE and still had the problem.Finally a good friend figured it was air flow trouble and replaced this.Don't criticize me cause I'm not up on the censers.The computer never thru a code and was diagnosed by process of elimination.Good Luck.
[Reply]  [No Email]
Thomas(AB)
08-26-2012 16:43:31
207.107.204.34
 Re: farm truck problem continued in reply to charlie n, 08-26-2012 16:10:38
that i believe is a mass air flow sensor, mine gets replaced every 3 years, caused alot of grief when it first quit working. never did throw a code for it.
[Reply]  [No Email]
Diydave
08-26-2012 15:40:41
96.244.152.143
Next time it starts acting up, hook a vacuum guage, to it, or take a can of starter fluid to any suspect vacuum hoses. If the motor speeds up, when you spray a vac hose, it means that hose is leaking vacuum.
[Reply]  [No Email]
wgm
08-26-2012 14:58:50
66.11.102.200
Take it to a professional if you want it done right.
[Reply]  [No Email]
Phil in Pa
08-26-2012 15:11:48
96.61.7.196
 Re: farm truck problem continued in reply to wgm, 08-26-2012 14:58:50
Yeah, auto repair shops being so cheap and trustworthy and all.
[Reply]  [No Email]
Monkey Run
08-26-2012 14:55:09
173.202.12.224
Make sure the catalytic converter/muffler have good outflow. Just something else to check. A pack rat built a nest in the air intake of my 94GMC 350, made it run lean, got the converter so hot it melted the matrix inside and plugged up converter and fried the oxygen sensor. Very similar thing on a mid 80's Toyota car I had, but never knew why that one fused the converter. Service guy knew immediately what it was, so I guess it was happening to others. Similar symptoms, at first you could start and run but after a few miles the back pressure would dog down the engine.
[Reply]  [No Email]
Dave in GA
08-26-2012 14:46:00
184.36.180.214
I would suspect a malfunctioning EGR valve or O2 sensor.
[Reply]  [No Email]
Jim in Ma.
08-26-2012 14:41:31
72.70.109.209
Codes? another problem could be a worn timing chain or gear. Most often it's the teeth on the cam gear that are bad.
[Reply]  [No Email]
DH in Carolina
08-26-2012 14:34:11
173.212.9.211
If you have a ground wire at the thermostat housing bolts make sure it is making a good connection. Had a crroded bolt on a 90 that caused all kinds of problems.
[Reply]  [No Email]
Bryan iniowa
08-26-2012 14:33:34
209.252.175.31
any codes ? Check fuel pressure ,,possible EGR leaking or getting vacuum when it shouldn't .
[Reply]  [No Email]
504
08-26-2012 14:29:49
64.111.61.44
TBI or Direct injection?
[Reply]  [No Email]
Morgan Flowers
08-26-2012 13:58:47
69.55.123.195
Have you checked the compression? Just an idea.
[Reply]  [No Email]
Wisconsin Cowman
08-26-2012 13:51:53
97.95.49.225
Did you check for codes?
[Reply]  [No Email]
Sprint 6
08-26-2012 13:47:56
50.102.25.80
I'd bet your exhaust system has lost its ground. The oxygen sensor won't work right if the exhaust does not have a good ground. Run a jumper cable from O2 sensor housing to the battery ground and see if it runs better.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
