Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: 8N digital gauge
[Return to Forum]
Krwkmt
08-23-2012 17:55:45
166.147.121.147
Any instructions on how to get a digital temperature gauge to work on a 12 volt 8N The gauge is inoperative when motor is running as if the ignition system is back feeding into it
[Reply]   [No Email]
Dell (WA)
08-24-2012 09:42:49
63.226.209.134
 Re: 8N digital gauge in reply to Krwkmt, 08-23-2012 17:55:45
Krwkmt.......surprizingly enuff, digital gauges don't like sparkies. And without sparkies, guess what??? Engine NO RUN. And even worse, yer 8N's weaksister ignition needs COPPER-CORE sparkie wires which generates sparkies to kill yer digital meter. While you "might" gitt some sparkie relief iff'n you use modern resistor carbon-core sparkie wires, it is NOT RECOMMENDED. Me? I use a tube operated mechanical temp gauge from Stewart-Warner (print matches other gauges) and the sparkies never bother it. ........mechanical Dell, retired electronics engineer
[Reply]  [No Email]
MarkB_MI
08-24-2012 02:05:51
75.241.116.92
That's just wrong!
You'll probably need to replace your plugs and/or plug wires with the resistor variety. You can try filtering the input by adding a capacitor between the input and ground as close to the gauge as possible. A second capacitor between the positive and negative power wires is a good idea, too.
[Reply]  [No Email]
oldtanker
08-23-2012 21:07:58
66.228.255.239
How man connectors on the gauge? If it's 3 like mine then one is power from the switch, one is ground and one goes to the sender. Plus you may have a couple for a light in the gauge. Mine is an electric gauge but it is anolog.
If it's hooked up the way it's supposed to be then I would guess interference.
Rick
[Reply]  [No Email]
Dean
08-23-2012 18:11:07
152.216.3.5
Most likely digital circuitry cannot tolerate the RFI interference from the ignition system.
Are you using TVRS or coopper core spark wires?
Dean
[Reply]  [No Email]
Popinjohn
08-23-2012 18:05:57
24.168.43.43
Isn't it like any other gauge where you have a 12v power source wire, and a wire coming from the sensor in the water jacket? If it is backlit, maybe a wire connected to dash lights for illumination? Do you have other things connected that shouldn't be? Also, you didn't say if your 12v system is negative or positive ground.
[Reply]  [No Email]
Krwkmt
08-23-2012 19:12:39
166.147.121.161
 Re: 8N digital gauge in reply to Popinjohn, 08-23-2012 18:05:57
Negative ground
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
