Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Break Help Wanted! (PICTS)
[Return to Forum]
Beatles65
08-21-2012 15:41:22
69.80.118.116
Working on the rear right brake with a neighbor and was wondering how to get this drum off this truck. Its a 1969 Chevy C/50 Dump truck. To remove the drum, do we have to take out the three flathead bolts?
Back behind that drum is a leak in the brakes that loses a lot of fluid!
Thanks!
From Denton, Nebraska.
Andrew Kean
This post was edited by Beatles65 at 15:42:44 08/21/12.
[Reply]   [No Email]
Bendee
08-22-2012 19:19:23
124.181.94.17
Re: Break Help Wanted! (PICTS) in reply to Beatles65, 08-21-2012 15:41:22
A Tea20 Ferguson Tractor has the same thing and yes they must be removed, so applying the same principle to your situation, I would say "yes".
i.e if you want the brake drum off.
  [Reply]  [No Email]
Hobo,NC
08-22-2012 04:29:48
67.141.239.103
Re: Break Help Wanted! (PICTS) in reply to j hikemper, 08-21-2012 15:41:22
Been awhile for me,,, I don't take the wheels off the hub either Wheels and hub come off together..
  [Reply]  [No Email]
Owen Aaland
08-21-2012 23:54:28
216.47.35.33
The three screws do hold the drum to the hub but if you can get them out you may spend more time trying to get the drum off the hub than it takes you to pull the hub and drum together. The brakes are a lot easier to service with the hub out of the way.
  [Reply]  [No Email]
Hobo,NC
08-21-2012 18:19:06
67.141.239.103
I never seen a drum on one of'em held on by screws,,, I don't even remember seeing those screws :shock: I have serviced a bunch of'em but its been awhile... Remove the axle and take a pix of whats behind the axle fer us...
You are in for a treat good luck...
  [Reply]  [No Email]
to_many_irons
08-21-2012 18:09:36
71.7.213.182
what red tom said . no seal to replace that way .
  [Reply]  [No Email]
redtom
08-21-2012 18:06:28
68.188.237.249
Some of the GM "corporation" axles have just a cover on the end, which I believe you have, which you remove. The axle shaft has external teeth and the hub internal teeth with a threaded hole in tha axle for a bolt to just pull the axle out. The hub will still need to have the locking nuts removed and the bearing etc pulled off. Point is, not all rear axles are the remove the nut/bolts and smack the end, style.
  [Reply]  [No Email]
Allan In NE
08-21-2012 16:44:31
148.66.88.254
No,
Those screws just hold the drum to the hub.
Take off the nuts at the end (sometimes, you have tosmack the axle with a two pound hammer to loosen the wedges), then remove them along with the axle.
Inside, you'll find two lock nuts with a lock washer between 'em or a locking ring. After you get these parts removed, the outter bearing, hub with inner bearing and seal can then be pulled off. It's a lot easier than you'd think.
One or both of the brake cylinders inside is leaking the fluid.
Allan
  [Reply]  [No Email]
XFARMA
08-21-2012 15:45:57
184.153.166.247
Easiest way I know of is to pull the axle and the remove the locknut, retainer, bearing nut, and then you should be able to pull the hub with the drum still on it. Saves a lot of work.
  [Reply]  [No Email]
rustred
08-21-2012 16:05:04
184.151.222.60
Re: Break Help Wanted! (PICTS) in reply to XFARMA, 08-21-2012 15:45:57
yep, second that, pull axle.
  [Reply]  [No Email]
Diydave
08-21-2012 15:45:36
96.244.165.234
I think those screws need to come out. Also you prolly need to back off on the adjuster screw, cause sometimes the drum will hang on a wear ridge, and not slide out.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
