| Author |
[Modern View]
| crispy cremer
08-14-2012 20:22:47
70.198.1.205
What pressure settings should I have on my guages for the acetelyne and oxygen when using a cutting torch |
| VicS
08-15-2012 19:52:11
70.195.1.24
Re: acetelyne torch in reply to crispy cremer, 08-14-2012 20:22:47
| Looks like you got a lot of good answers. All the (Junkers) use Lp. A grill bottle of LP will outlast at least 4 big bottles of oxygen. Our local scrap yard uses a 1000 gal tank of LP and a Semi-trailer of liquid oxygen. Cutting up coal mine equipment up to 12 inches thick. It takes a little longer to to heat your metal hot enough to cut with LP. But seems to cut cleaner, for me at least. |
| JOB
08-15-2012 18:36:34
74.36.131.224
| | I was told 5 Acetylene and 20 oxygen. From many years of experience 7 acetylene and 40 oxygen works the best for me. If your torch has two oxygen valves on the handle you should open the one closest to the regulator wide open, and use the valve closest to the tip to adjust your flame. You should not empty an acetylene cylinder in less than 7 hours. If you do acetone will be in your acetylene. Acetylene tanks are filled in 7 hours also, unless the process has changed. A tip will only handle so much pressure. To see how much pressure your tip will handle set your acetylene at 3 pounds, set your oxygen at 3 pounds. Light your torch, open your acetylene valve all the way. You should have a very sooty flame, increase acetylene pressure slowly, your flame should be connected to the tip. When the flame leaves the tip you have too much pressure, decrease pressure a tad. Adjust acetylene valve so flame is connected to end of tip. Now open your oxygen valve on the torch all the way, increase pressure until you get a neutral flame. That is all the oxygen pressure you need to run that tip. The above information is for gas welding and brazing, and welding tips in general. If you starve a tip for acetylene it will pop out. If you have too much pressure on your lines your are using the valves on your torch handle for regulators. |
| Stick welding
08-15-2012 20:55:32
96.53.210.246
Re: acetelyne torch in reply to JOB, 08-15-2012 18:36:34
| | You're partly right but for equalizing a welding tip you don't even need a gauge on the regulator. Some acetylene cylinders will be empty in 10 minutes. The withdrawal rate for acetylene is 1/7 of the cylinder capacity per hour not 7 hours. This can be exceeded for short periods if you're using a heating tip for example. Similarly larger acetylene cylinders take longer to fill but they usually fill more than one at a time 20 PSI oxygen is probably good for about 1/8" material. 40 PSI will cut over an inch thick but it depends on which size of tip you are using. |
| JOB
08-16-2012 05:01:24
74.36.131.224
Re: acetelyne torch in reply to Stick welding, 08-15-2012 20:55:32
| stick weld your first two sentences don't even make sense. I am not a mathematician, but doesn't 7 hours equate to your withdrawal rate. The withdrawal rate for acetylene is 1/7 of the cylinder capacity per hour not 7 hours. I have emptied large acetylene cylinders in 3 or 4 hours using a #15 tip and never seen a black type liquid as you mentioned in another post. I have seen the flame look a little different, maybe a little feathery. I assumed that was the acetone burning. 7 lbs of acetylene and 40 lbs of oxygen works for me. I can cut clean and quick. And I use a #1 tip. You set your pressure at anything you want, whatever you like. What ever works best for you. |
| Paul from MI
08-15-2012 17:59:39
204.106.250.243
| If you go with propane, as I have, be sure your get compatible hoses. Regular acetylene hoses will fail after a time. Propane works fine for cutting and brazing, not too sure, never welded with it. |
| Stick welding
08-15-2012 20:57:22
96.53.210.246
Re: acetelyne torch in reply to Paul from MI, 08-15-2012 17:59:39
| Only an oxy/acetylene flame is a true neutral flame and that's why it is the only fuel that can be used for welding. |
| JML755
08-15-2012 16:47:26
24.192.222.226
Re: acetelyne torch in reply to NCWayne, 08-14-2012 20:22:47
| Quoting Removed, click Modern View to see
Stick,
good info. thanks. |
| JML755
08-15-2012 10:28:14
97.78.165.183
Re: acetelyne torch in reply to GordoSD, 08-14-2012 20:22:47
| Quoting Removed, click Modern View to see I use no higher than 5 on mine, just what I read in the manual and by looking at the charts. The 15 is not a working pressure as stickweld says. |
| Stick welding
08-15-2012 09:40:32
96.53.210.246
| Can't believe some of the responses! 4 PSI of acetylene will cut over 8" thick. For general cutting on say 3/8" steel, 4 PSI acetylene and around 30 PSI on oxygen is a good starting point. You can adjust the oxygen pressure to suit the thickness you're cutting. Acetylene pressure won't make any difference at all. If you're using a heating tip, then you need to increase the acetylene pressure. Having a clean tip and a nice long straight cutting jet will do more to produce a good cut than having an exact pressure setting. |
| RodInNS
08-15-2012 07:20:29
216.118.158.123
| As always it depends on the tip size... but 5 on the acetylene and 15 for O2 is a general rule of thumb. If you're cutting something and it doesn't burn off clean then you need more O2 pressure... I use propane rather than acetylene myself... and with LP I will run 10-12 # on the gas pressure... but always remember that acetylene is unstable in free air at pressure greater than 15 psi. It can explode. BEst to keep it's pressure down closer 5 psi.Rod |
| CBBC
08-15-2012 12:46:38
96.54.255.80
Re: acetelyne torch in reply to RodInNS, 08-15-2012 07:20:29
| Thanks Rod, I was going to ask about propane. I'm paying for tank rental and hardly use the torchs. I think I will try Propane and only pay the rent on my O2. I have a few BBQ style tanks and I know my regulator will fit the valve, but will the propane work on my forklift bottles? I know I will need an adaptor... What pressure do you run the O2 at with the propane? Thanks, Grant |
| CBBC
08-15-2012 18:09:27
96.54.255.80
Re: acetelyne torch in reply to CBBC, 08-15-2012 12:46:38
| Thanks guys, I think I will get a LP tip and see how it goes. As I said I have a lot of propane bottles as well as propane for forklifts. I'll ask my propane guy about the tanks. Grant |
| Russ from MN
08-15-2012 13:41:05
68.235.89.1
| The forklift bottles that we used were liquid withdrawal, but there was another port for vapor, which is what you want for a torch. This port was plugged, so there would have to be a fitting installed. I think most forklifts use a special fitting, ours did. |
| RodInNS
08-15-2012 13:10:07
216.118.158.123
| I don't know about the forklift tanks.... I would assume that they have the same valve on them since I don't recall anyone around here having a different fill whip for forklift bottles.... but honestly I've never looked. You may need to install a couple long nipples on the regulator to clear the neck ring on the BBQ tanks tho.You also need LP tips for your torch... I run roughly the same O2 pressures. Mabey a bit higher. Basically just what you need to make it work right. Rod |
| JOHNNYfromMI
08-15-2012 06:30:58
74.115.62.95
| 15 is the MAX on the acetelyne! Any higher than 15# pressure the gas becomes unstable and can ruin your day! |
| Walt Davies
08-15-2012 13:54:42
174.253.194.165
Re: acetelyne torch in reply to JOHNNYfromMI, 08-15-2012 06:30:58
| How does that work when it's 350 in the tank. A lot of old wive's tales out there. Walt |
| Stick welding
08-15-2012 15:38:44
96.53.210.246
Re: acetelyne torch in reply to Walt Davies, 08-15-2012 13:54:42
| Wive's tale? There is a porous material inside an acetylene cylinder that is then filled with acetone. The acetone absorbs the acetylene gas so it is stable above 15 PSI. When filling an acetylene cylinder the amount of acetone is measured and then the appropriate weight of acetylene is added. The fill pressure is 50 PSI and it still takes a long time to fill. The maximum size of pipe for filling is 1/2" and it's double extra heavy pipe. When filling the cylinder is cooled with water. Why do think acetylene cylinders are so heavy? Have you ever noticed a black type liquid when using a rosebud? It's from withdrawing acetylene too fast and is the acetone. I toured a cylinder fill plant. |
| bill mart
08-15-2012 14:07:36
69.204.65.189
| How it was explained to me: "Gaseous" acetylene is unstable over 15 psi, which is why it's dissolved in liquid acetone in order to store it at ~275psi. Bill |
| gene bender
08-15-2012 04:53:18
67.55.226.123
| The settings are determined by the tip you are using and the tip is determined on how thick is the material. Most people use more pressure than they need.Get a chart it will tell you how to set for the tips same with using the welding tips. |
| MarkB_MI
08-15-2012 02:44:56
75.219.29.52
| Most torch manufacturers post tip charts on their web sites. Settings vary widely between different tip sizes and different torch models. |
| 504
08-14-2012 21:20:00
64.111.61.44
| For OX what ever works for you, for Acetylene 15psi is the max, 16 and you could have big problems. I run 8 to 10 and have cut 3/4 inch steel. |
| Walt Davies
08-14-2012 21:08:18
174.253.202.16
| 10 to 15 lbs on the acc. 30 to 40 on the oxy. Adjust up or down according to tip size. Walt |
| flying belgian
08-14-2012 20:27:59
98.132.233.132
| Really depends on the situation but try 15 and 50 for starters. Then as you are cutting you will see why you want to change either one. |
| Russ from MN
08-14-2012 20:27:10
68.235.89.1
| Depends on tip size, I think 4&20 will work. |
