I have a John Deere 730 diesel and just below the hydraulic connectors for the remote cylinder, I have a leaking freeze plug. I removed the freeze plug, drained the hydraulic fluid to that level, and replaced the freeze plug and used RTV this time. Same result, it leaks.
Any ideas to fix this leak permanently? The hole behind the freeze plug is only 1/4" or so.
Also, I was told that you are not able to drain this below the freeze plug. Is there a way to get this drained out completely?
