Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: 1989 Ford ranger truck problem part 2
[Return to Forum]
old
08-08-2012 20:46:01
209.86.226.30
Got the chance to check it out today. Found after checking for a clogged exhaust and fuel that it has no spark from the coil. That said the engineer who designed this truck should be shot quartered and then hung. I would have pulled the distributor cap to check for rotor rotation but it is all you can do to see the distributor let alone pull the cap on it
[Reply]   [No Email]
GordoSD
08-09-2012 09:24:43
64.33.250.162
 Re: 1989 Ford ranger truck problem part 2 in reply to old, 08-08-2012 20:46:01
Maybe try
[Reply]  [No Email]
tedregentin
08-09-2012 06:05:46
216.110.201.79
Old, they look worse than they actually are to do. Take the wires off the plugs on one side of the engine, take the distributer cap off and it is much easier. Most likely, the TFI module has gone bad. Very common failure. There is a special socket that makes removing the two small bolts that hold the module to the side of the distributer. If you change it, do not go with a cheapie. Make sure you use the grease that helps dissipate the heat.
Ted
[Reply]  [No Email]
Hogleg
08-09-2012 05:54:57
38.104.162.74
Just be glad you don't have the SOHC version they started putting in the late 90's explorers and rangers. Have to pull the engine to change the timing chains, because the engineers decided to have only one head design and then placed one with the chain in front and the other on the back of the block.
John
[Reply]  [No Email]
ASEguy
08-09-2012 05:47:11
68.186.162.134
Mechanics have been threatening engineers for years. With the old Escorts we had to grind down the outside of an old socket to make it "fit" the opening. Another great idea. Be careful with your back and let me know how many words you string together to describe the part removal. LOL Gerard
[Reply]  [No Email]
earlschieb
08-09-2012 07:27:06
24.209.244.149
 Re: 1989 Ford ranger truck problem part 2 in reply to ASEguy, 08-09-2012 05:47:11
Nope, just buy the aftermarket socket, wasn't expensive, and I have made a lot of money thanks to that socket.
[Reply]  [No Email]
cole in mo.
08-09-2012 04:54:18
65.255.149.240
The firing order is 1 4 2 5 3 6 and looking at the dist from the radiator, it turns clock wise.
[Reply]  [No Email]
MarkB_MI
08-09-2012 02:35:54
66.87.7.198
The ignition system lasted 23 years with zero maintenance and you're upset because it's a little difficult to get to?
[Reply]  [No Email]
old
08-09-2012 09:00:27
4.244.222.61
 Re: 1989 Ford ranger truck problem part 2 in reply to MarkB_MI, 08-09-2012 02:35:54
Well if it was a little hard to get to that would be ok but this is a lot hard to get to plus it is 35 miles from me to boot so hard to know if I have the correct tools with me to do that job
[Reply]  [No Email]
old
08-09-2012 08:59:19
209.86.226.19
[Reply]  [No Email]
Dick2
08-09-2012 01:23:08
174.26.218.15
That was all part of Ford's grand plan to sell more parts back in those days. Our daughter knew a guy at Motorola where they made Ford's ignition modules. Ford insisted that the module be designed to fail about every 50,000 miles, which most of them did.
However, Ford's alternate supplier of modules was a Japanese company that refused to design them to fail. If you want a module for a Ford that isn't designed to fail. look for one that was made in Japan.
[Reply]  [No Email]
The tractor vet
08-08-2012 22:11:12
76.212.225.255
Ah the old 2.9 and the lose of spark. More then likely the TFI modgel on the back side of the dist. What a pain in the donkey to change , special tool helps some , small hands with nimble fingers helps more . I had a 88 ranger with the 2.9 and replaced that twice . Still have a 2.9 spare that only has 64000 miles on it that i would love to get rid of .
[Reply]  [No Email]
wisbaker
08-08-2012 21:07:14
207.118.135.5
What engine? If it's the 2.3 remember that basic engine was intended for something else and they didn't foresee all the garbage our uncle in Washington was going to require as well as the buyer insistence for more options like power steering and air conditioning. On some of their newer 4 cylinders like the Escort they hung the dizzy off the end of the camshaft were it was pretty easy to get to and remember they're also the folks that liked to put the distributor in the front of their V-8s. As far as the shooting and quartering let's hope it got done before they reproduced, hate to have another generation waiting in the wings.
[Reply]  [No Email]
old
08-08-2012 21:19:34
209.86.226.30
 Re: 1989 Ford ranger truck problem part 2 in reply to wisbaker, 08-08-2012 21:07:14
2.9 V-6 with fuel injection so the distributor sits behind and under the injector rack so you have to be able to climb into the engine area just to see it and then you have the have the hands f a 5 year old to get to it
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
