| Tractor Talk Discussion Forum |
Topic: starter rebuild
[Return to Forum]
| Author |
[Modern View]
| bkpigs
08-06-2012 19:58:23
24.182.238.167
The starter on my Farmall A grinds sometimes when trying to start. I was thinking of rebuilding it myself and save a few bucks. Where should I start for parts and supplies? Is there an online resource you guys like or just a good local auto parts store? Thanks! |
[Reply] [No Email] | |
| Texasmark1
08-07-2012 05:35:41
67.142.175.26
Re: starter rebuild in reply to bkpigs, 08-06-2012 19:58:23
| | I had an old Ford starter that I thought I rebuilt several times. Finally it would short to the frame requiring a hit with a hammer to cause the armature to BOUNCE enough to get it spinning. Seems that the problem was the armature shaft that rides in the bronze bushing was reduced in diameter allowing it to strike the case. New starter solved the problem and I didn't have to split the tractor and redo the ring gear like I originally thought I'd have to do. Starter was new and I bought it for about $150. Money well spent. I think I went on line looking for it. Don't remember where I got it nor where it was made. It works great whatever. Mark |
| gene bender
08-07-2012 02:56:11
67.55.226.123
| Probably need to split the tractor and install a new ring gear. If it isnt too bad you can remove turn it around and put back on. You will need a torch to get it warm enough to remove clean the grouve on the flywheel and re-install then get a new Bendix get the starter refurbished brushes maybe a bearing or two and it will start like new again. Also clean the connections starting at the battery mite also need a new saddle sw. Ive done them many times. You have a choice of the Bendix as there are two types available either one will work for many yrs to come. |
| Fixerupper
08-06-2012 20:06:38
100.42.82.164
| When you pull the starter, look in the hole to see what the flywheel teeth look like, all the way around. I'm not saying the starter drive isn't bad, but the flywheel just might be the culprit too. Could be a combination of the two. Jim |
| Janicholson
08-06-2012 20:03:44
96.24.99.126
| If by grinding you mean it spins but fails to turn the engine, making gear stripping noises, It might need a new drive pinion assembly. There is a new style that is totally different, but installs with ease. It seems to fix multiple grinding and jambing issues. This site sells good parts, and they are available from many sources. I would put in new bushings, and new brushes. Having the armature turned true with a minimum cut (lathe) is also good practice. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
