In have a 2940. It has a lever on the lower left side of the seat to engage the parking brake. There is an indicator light on the console that flashes to let you know you left the brake engaged. It operates off a switch at the base of the handle that is just a spring loaded cheap switch. My switch has been damaged and the indicator remains on all the time. I tried twisting the wires to the light together-light stays on. I tried insulating them from each other too. Neither seemed to work to put out the light-light stays on. Will a new switch work or is there a way to deactivate the idiot light permanently?
