FrontEnd Loader hydraulic pressure issue solved.
Shealray
I brought a hydraulic ball valve rated 2000 psi and installed it to the down pressure hose on the front end loader. I now turn the valve to the off position before disconnecting and the pressure is contained. Now after using the round baler I can connect back to the front end loader. By the time I purchased the ball valve, nipple and pipe dope it was about $50.00. I figure I will save a lot of money in hydraulic fluid and my time.
Thanks to all who helped.
Farmers are the best.
