Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Ford F150 4.2
[Return to Forum]
James Williams
07-25-2012 11:07:31
170.215.50.10
After the first 10 miles while driving I get dentonatin,or valve plng,mostly at high RPM when Im on the throttle,Ive cleaned the PCV valve,checked the MAF.Im to the point of wandering if I have a manifold leak.I checked the codes and they are PO 171 & PO174,need your help,Seemed like it started all at one time,its 175,000 miles on the motor.The truck Idels and runs good
jimmy
[Reply]   [No Email]
robgIN
07-25-2012 16:53:29
70.224.33.205
 Re: Ford F150 4.2 in reply to James Williams, 07-25-2012 11:07:31
those codes are for lean bank 1 and 2, so most likely a vacuum leak, pcv hoses and elbows are the most common problems. With that many miles could be upper plenum gaskets getting hard and leaking also. The egr on that engine goes into a port along the center of the intake and it has orifices into each port. Those orifices tend to plug with carbon over time and block the flow of egr causing ping, many times all but one or two port will be completely plugged and all the flow goes to 1 cyl and it feels like a miss.
[Reply]  [No Email]
wisbaker
07-25-2012 12:34:38
207.118.151.73
Had a similar problem on an 01 F-150 with the 4.6. Problem went away when I changed the fuel injectors, I suspect one was not passing enough fuel and the cylinder would get to lean and she'd knock. For what it's worth Ford couldn't diagnose it and my dealer claimed it's normal and they all do it. Goggle the codes they might tell you something it might have something to do with a temperature sensor so the computer is not setting the right fuel mixture when it's cold.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
