We purchased this property a month ago. 25gpm well, with a 12
gpm submersible pump. Pressure tank is a 20 gallon model
H20.
Pump fills from lo to hi pressure in 15 seconds, pumping 3
gallons. Tank has 28 psi above bladder - right on spec.
Conclusion is that it has an undersized tank for the pump/well
capacity.
Rather than swapping out the H20 tank for a larger one (to
increase pump run time), can I install a second tank (larger than
the H20) and plumb them in parallel so that both are operating
when water is being used. I have the space for two tanks.
H20.
capacity.
