luckybodog
I had posted a message about My 1969 Massey Ferguson 135 I use for bush hogging . The bush hog getting to low in front and twisting the drive shaft into.A friend of mine told me to try this over run clutch that slides on the PTO shaft . I have read were it helped some tractor from lunging froward.but the problem I have is I can"t get the bush hog up before the Pto shaft twist into . The ground being unlevel. I have a Two stage clutch so I am not sure the over run clutch will help any.I have all so read about the limiter chains. I don"t want to waste money on the over run clutch if it won"t help. Any suggestions?
