3pt top link hook-thingie
I"ve got a beloved "71 JD4320 that came with a top link on it"s 3-pt that ends in an upside-down hook-thingie** for attaching to implements. It looks like it was stock, so I assume at one point it was a standard 3-point variation that Deere sold back then. Possibly, some form of early quick-release mount than never became a standard.
I"m interested in figuring out what this style of top-link connector is, and what the "correct" specs are for it, and what its original purpose was.
Anybody know what this style of top-link was for, and what it"s name is so that I can look up information on it?
**Better description of hook-thingie: It as a big cast-metal piece on the end of the top link that is designed to be placed downward (IOW, the open end is on the bottom) onto a roughly 2 inch diameter hitch pin (much larger than a standard top link pin) When you lower it down, a small piece latches underneath to secure the implement, and there is a top lever you pull to retract the pin and release the top link.
Not quite understanding the question. That was the standard top link. You used a ball on your implements and that link hooked up faster than lining up a pin and putting it in. I don't know why you'd want anything else on it?
Hooks down on a ball started around the 620 era tractors pain in the axe sometimes you have a ball and sometimes not when you have differant make tractors with differant top links
<img height="300" width="591" src="http://jdpc.deere.com/pimages/RE02/RE029770_______UN20JUL98.gif">
OEM for the tractor. It sounds like you just need to pick up a ball for it (part number F2681R).
All three of my Deeres (4010, 4020, 2950) have the same style but all slightly different design. Starting in the 1990s with the 6000 and 5000 series tractors, I think the hook style top link was only available as optional equipment.
I don"t want anything else, but I do want to look up the specs so that I can figure out the best way to fabricate ball substitutes on my implements. I"ve never seen a "real" ball, so I don"t know if there is anything I should be emulating when I fabricate one, or ever what the names are to try to buy one.
These are the spec's listed in JDparts.com
Part Number: F2681R
Part Price: 20.25 USD
Description: BALL, PLATED, PART HAS SUB
Specification
Weight 0.82 LBS 0.37 Kg
Nominal Diameter 1.988 IN
Hole Size 1.015 IN
Width 2.000 IN
Diameter of Flat 1.311 IN
Grade 30T
Hardness 48-55
Material 4140
Finish C
you could maybe make one if you would by one from deere to get size ect,but they are heat treeted so it may be easer in the long run to just by two or three
You have the standard top link. You hooked a short rope to the release handle and you could trip the top link from the seat while you worked the controls to take the weight off of the hitch.
The top link implement balls from your local JD dealer are not that high. They are A&I supplied. The JD part number is over $35 dollars.
Here are the correct numbers that your JD dealer can use to get the cheaper ones for you.
A-F2680R Cat I $4.88
A-F2681R Cat II $4.80
You must have a lot more time on your hands than I do to make them when they can be bought for less than $5 each.
Whenever I bought a new 3 point implement after I got my first hook type hitch, I'd get a new ball and a long pin for the top link mast. If I was using the hook type toplink, I'd slip it into the mast while I was hooking up. If the toplink had the ball in it, I just pull the pin out, and store the ball on the long end.
