A 10 lb sledge and an oak block of wood has never failed me. I also spray a little blaster or whatever I have handy into the piston tops.
As a piston moves I steel wool the sleeve to remove any crud build up. Once it is moving I
spin it with the starter. Last but not least, I
wire wheel the head and the engine block. Next I apply a high temperature permatex to both sides of the gasket. Finally I torque the head bolts 5 psi beyond spec. This procedure has never failed me yet.
