Used fence posts
Case e,
A NEW 6" - 8" diameter, 8 feet long, pine, creosote coated fence post a the Maury County Farmer's Co-Op in Spring Hill, TN, sells for $22.95.
I guess a USED post should be less than that by an amount that represents the condition of the post.
Good luck and come on down to Spring Hill with lots of money - our economy needs it.
Tom in TN
Fellow who used to be a regular on these forums sold the holes for 'em........cut to 'your' length; never seen many used fence posts sold.
Really common here, a lot of the bigger horse farms replace plank fence every 7-10 years rather than repaint and replace boards. Ive been getting 6 inch faced x 7.5 for plank fence 5-7 years old for 3.00 each, in 100 post quantities. New 6 inch have been running me 10.00 even by the bundle, 5 inch 8.44 by the bundle.
CAn you point me to a source for the black fence paint? The kind you can mix 50-50 with used oil? Can't get it here anymore and I have 1/4 mile of black board fence to repaint.
email is open
Not all RR ties. We've been using them for corners, corral posts, etc., here on the ranch for about 15+ years now. We buy 'em by the semiload and some are good and some are barely usable for landscaping(usually those are in the middle of the bundle). Can't count how many I've had to replace due to rotting off or snapping off if someone bumps them with an implement or cattle rub on them.
By the same token, we have some old hedge posts that've been in the ground for 70 years or better that are still solid as the day they were set.
One other good thing about the hedge posts is they usually taper out towards the bottom and will stay in the ground alot better versus a straight-sided RR tie which needs to be very well braced if used for a corner.
I've never bought a used fencepost but I've re-used lots of them from when we've moved fences, etc. to make repairs on other fences. I can't see a problem with putting a solid 30 year old post in a 50 year old fence.
Dad gum it .. Just sold the trailer too. thems hard to come by. heck we could have used them to. got a lot of big rocks here and we coulda just set em on top without digging ..Sheese !!!
