pellet stove
I have a quadra fire pellet stove, that won"t work on the low setting.It runs for about 15 minutes, and then it goes out.It runs ok on any other setting.Can anyone tell me what is the problem?
Thanks George
There is a website called I Burn Corn that deals with different brands of corn and pellet stoves. They are very good at helping and can diagnose a problem by asking you different questions.
There is a very good Quad tech called Cap that would help you.
(quoted from post at 07:22:45 12/19/11) I have a quadra fire pellet stove, that won"t work on the low setting.It runs for about 15 minutes, and then it goes out.It runs ok on any other setting.Can anyone tell me what is the problem?
Thanks George
try http://www.nepacrossroads.com
a forum that deals with all kinds of stoves
I have the same problem with my Pellet burner, it is a US stove brand. There are 9 settings on it. If it is on setting "1" (the lowest) the feed rate to the burn pot is not high enough for the burn pot to keep the pellets burning. (I havent ran corn through the stove in years)
The lowest setting I can run it on is 2. I have ran the stove for 5 winters now.
(quoted from post at 15:22:45 12/19/11) I have a quadra fire pellet stove, that won"t work on the low setting.It runs for about 15 minutes, and then it goes out.It runs ok on any other setting.Can anyone tell me what is the problem?
Thanks George
Sound like you need to fine tune the low feed rate. I can on my Glow Boy. The bottom page shows how i can set mine.
