Fritz Maurer
Got a Miller Roughneck W/ OHV140 Tecumseh. Want to repower with a 16hp Briggs, however, the Briggs has no alternator under the flywheel to excite the welder. It is equipped with a motor-generator. Can I use any part of this system to excite the welder? My concern is running 12VDC to the rectifier. The original Tecumseh method for exciting the welder was just a single pole winding, powered by the magneto magnet (under the flywheel). The engine did not charge it's own battery. There was a separate winding in the welding alternator for this purpose. The ignition unit (outside the flywheel) was solid state with two wires: a kill wire and the high tension lead. Thanks for any input, Fritz
