lehman little dipper skid steer
vvc5200
New User
i have read in the archives that the company in hecla, sd. was sold to an ltd co. in in. or il. i need to find the slip joint flex coupler located between the engine 1.75" shaft and the 12 splined shaft 1/2"? can anyone help me. thanks
So you have the Sundstrand tandem pump or the Cessna pump. I think you are off on your tooth count. They used 11 tooth and 13 tooth. Cessna had 13 and Sundstrand had 11. Need to know what you got so I can get you the correct number. Unverferth Manufacturing owns the rights to the company. They are pretty much useless with parts some people know what you are taking about when you say Lahman. Most don’t have a clue. Most parts for they skid loaders are easy to find if you know the suppliers they used back then. I will have count my teeth on my junk coupler. I believe LoveJoy makes a coupler that will work have to double check.
I have a used coupler from the Lehman skid loader I had.
I changed out motors after the Kohler motor went bad and had to make a coupler to fit the Briggs motor.
I assume you still have the Kohler K532(I think that was the model).
Gary
what = the value of one and more importantly where is the company at that bought the lehman company thanks for responding
thank you for the info. i love their wagons i am over joyed. i thought i counted correctly but have been off most of my life. i looked at love joy but did not know where to find it 712 225-5467 after dark. thanks [email protected]
it does have 11 teeth. darn bifocals or i ran out fingers and thumbs thanks. the number of teeth that fit the outer hub is 22 if i counted thoses correctly. it measures about 2.75" from diameter.
