Anonymous-0
Guys with the red& white IHC.... Do you have a fuel level gage on the dash? If so, how does it work? Wiring diagram looks like the wire going to the tank s a ground wire. If so, grounding it to frame should cause the gage to read full??? Haven't taken anything apart and don't wanna bother the kid I got it from with a cosmetic thing (just as easy to open the cap and look inside. At the same time, I believe that if something is there, it should work.
Other than that, the PTO dripped a couple drops overnight and needs a new O-ring on the oil filler cap. I's happy and picking up the stuff to fix it on the way home.....
