tractor weight
I have a cast iron? weight that measures appx. 3' long, 2 1/2" thick and 10" across, weighs roughly 200 lbs. it used to hang between the rear tires of a farmall H. any ideas what it's for? I am heading to the scrap yard tomorow ad just wanted to know if I should lug it along. I have no use for it as it would not work on the wd45. also have a 150lb universal wheel weight.
JD, Sound like a old Elevator Wt. It is a counter balance wt. Use on elevators in buildings , stores, and Apt blds! They make them out of Cast iron and lead. Hope this helps
Later,
John A.
I don't use photo bucket any more since I found this, let it load up and click library and upload pic and resize if you have to -- save and share --- then use the upload here to post.
Picnic
Decided to keep it and put it On the WD45 when I finish the resto as It's getting a Freeman trip loader put on and I drained the fluid out of the tires and I need some counter balance. 8)
