2294 won't move no hydraulics at all
If it will work for a little after it has set for awhile I would suspect that a brake disc has come apart and plugged the suction screen.First you need to change the filters,when doing that see if the oil is murky looking.That would also point to the brakes.
Might be the torque limiter between the engine and trans. If it is, you will need to have it hauled in and split unless you are able to do it.
Not too bad to get it done.
That happened to my Ford 8240 three weeks ago. It was only the hydraulic pump. $5300.00 for the pump only.
Does it have hydraulics if you put it in park??? Low pressure if you dead head the the hydraulics?? If it does then the trouble could be the disk that drives the transmission. There is a clutch disk on the flywheel that is to protect the transmission when suddenly shifted up or down. I think that they called it the torque limiter disk. I have had them brake the hub out and then you lose all hydraulics and ground drive. Id they start slipping then you can have drive and hydraulics but only if you don"t pull the tractor.
I hate to get basic, but was it whining when running before? Pump on my 2294 was making such a whine last year, I replaced it before It came to a standstill. The 2 pumps come as one unit now in case your troubles lean that way.
As others have said its probably the torque limiter...A few years ago I was driving my neighbors 2290 Case pulling a field cultivator..It suddenly stopped and it was the torque limiter..
