560 farmall
I have a 560 farmall gas and the hydraulics are not working right. The 3-point is a fast hitch and it only goes all the way up or all the way down. The lever that switches the pressure from the front loader and then to the 3-point will not stay in position. When we use it it always goes back to the middle where it dosent get any pressure. If anyone has any answers please let me know thanks.
I think the issue is the pilot control (the valve you are moving is a remote valve dead headed to nothing. It is supposed to return to the middle. but if the pilot orifice in the system is plugged up (small screen) or stuck, it will not pressurize the system correctly. You may also have a draft control link out of position inside the rear housing (not sure on that). Jim
