PROPANE PROBLEM
BUDHIGG
New User
I HAVE A 40210 LP GAS TRACTOR. I'M HAVING A FUEL PROBLEM. WHEEEN IT STARTS IT WILL NOT EXCELERATE TILL IT RUNS FOR A COUPLE OF MINUTES, THEN YOU CAN OPEN IT UP AND IT RUNS SMOOTTTH, BUT WILL PULL DOWN WHEN PUT UNDER A STRAIN. IT SEEMS TO BE IN CARB, CONVERTER OR GOVERNOR. IHAVE CLEANED ALL THREE AND ALL PART SEEM TO BE ON GOOD ORDER. THE FUEL MIXTURE SEEMS TO BE THE PROBLEM, BUT I CANT FIND WHICH IS PROBLEM. ITS FIRING GOOD AND IN ORDER. ANY SUGGESTIONS.
Do you see anybody else typing in all capitals? Ever wonder why? Are you following engine operation procedure from the operator"s manual?
