exhaust lift
ldintn
Thanks for all the help in the past. So now I need a picture of an exhaust lift, the side with the cylinder on it and the cylinder lies flat instead of standing up. Thanks for any help. Libby
Only ones I have seen were vertical cylinders on Farmalls. Had to have everything right up to snuff to operate properly. All parts of the lift had to be virtually leak proof, and engine had to be running well - valves, compression, etc. Was not impressed with the one I was given to mow off roadsides for the county years ago.
The cyclinder laid flat on many implements which one do you need. The cult was the only on that used the cycl standing up. Mower,lister,planter all laid down.
I have a # 18 HWY mower for my A. The cylinder goes from off the front cultivator mount at an angle (maybe about 45 degrees) back towards the area in front of the steering wheel. Lifts the mower pretty well.
Mr. Gene, this is the lift I bought from you a year or two ago. I have everything mounted but the cylinder. I need a picture to see how and where to mount it. I still do not have an implement for it yet, so it will be just for show now. Thanks for any help. Libby
