Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cummins missing.
Lyndon - AB
05-12-2012 08:15:48
Lift pump broken or partially plugged?
Not very experienced with the dodge's, but had a delimber that had similar symptoms. Turned out to be a mostly plugged inlet line to the lift pump. Let just enough fuel through to run, but no power, stumbling, etc. Had to steam all the dust and crap out of the fuel tank.
Another possibility is air entering the fuel stream. If you put a clear line in between the filters and the injector pump, you can see if there are any air bubbles in the fuel stream.
Hope that gives you a few things to go on.
Lyndon
Copyright © 1997-2015 Yesterday's Tractor Co.
