Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: F350 Frame width
Banditfarmer
04-25-2012 05:15:53
Well both trucks on the Vin # tag on the door jam say the same thing, INCOMPLETE VEHICLE MANUFACTURED BY FORD MOTOR COMPANY. Both trucks were built in the same truck plant in KY and were built 3 months apart in 1995. I talked to a Big Ford truck dealer (they sell F350 up only) and they said with that tag reading INCOMPLET it should be 34" wide frame and not 38" but it had to be special ordered to get a Extend Cab in a cab and chasse set up. Who knows what Ford did when they built it. I still like it runs and pulls good and at 19 mpg I wont complane! Bandit
massey333
04-26-2012 07:31:35
 Re: F350 Frame width in reply to Banditfarmer, 04-25-2012 05:15:53
What you can buy is a pickup with a bed delete,which sounds like what you have and it would have a 38"frame while the other truck is a true chassis cab truck.Both trucks would have been marked incomplete.
John in La
04-25-2012 06:27:00
But what does position 5 6 and 7 of the vin number say.
They changed over the years so it may be differant for your year but Ford could tell you.
The 5th spot should be a letter.
F regular cab
X supercab
W crewcab
Spot 6 and 7 34 and above is a chassis cab
33 and below is a pickup
Brealing it down more
The first # 3 means 350 The second # tells chassis and rear wheels.
30 and 34 4x2 srw
31 and 35 4x4 srw
32 and 36 4x2 drw
33 and 37 4x4 drw
Banditfarmer
04-25-2012 16:43:52
 Re: F350 Frame width in reply to John in La, 04-25-2012 06:27:00
Thanks for the information I will but it to good use and add it to the other information that I found for and on this truck. Thank You Bandit
Copyright © 1997-2015 Yesterday's Tractor Co.
