| Author |
[Modern View]
| Ralph Bauer
03-18-2012 08:51:05
75.107.19.224
Will be putting a HD 12000 lbs winch on my GN trailer. Most smaller winches (2-3K lbs) have long cables to run of truck's batteries, or have wired in connections similar to hay bale spikes, but I am a bit leery to do that with this winch. Leaning toward a separate battery. What size amps, type battery? Deep cycle marine? Hard to tell what use I will have for the GN, will be an addition, not a replacement. Guessing once a month. Mostly to "recover/load " fence row finds and auction items. Thanks in advance, Ralph. |
[Reply] [No Email] | |
| buickanddeere
04-19-2012 16:19:10
216.183.156.15
Re: To buy a separate battery for winch operation? in reply to Showcrop, 03-18-2012 08:51:05
| Quoting Removed, click Modern View to see
The trailer battery is being supplied with the same voltage regulated power provided to charge the starting battery and operate the electrical auxiliary loads. If anything the trailer battery will be slower to charge due to vd. |
| johndeerefan
04-19-2012 07:46:54
216.135.37.250
Re: To buy a separate battery for winch operation? in reply to Ralph Bauer, 03-18-2012 08:51:05
| If you are supplying a constant 12V current to it while you are plugged into your truck, wouldn't it overcharge your battery. I thought that is why alternators/gennys have a voltage regulator. Am I thinking about this all wrong? |
| johndeerefan
04-16-2012 09:03:24
216.135.37.250
| Don't you have to install some type of regulator between the 12V plug and the battery? I would think you could over charge it. |
| buickanddeere
04-17-2012 11:58:31
184.151.61.115
Re: To buy a separate battery for winch operation? in reply to johndeerefan, 04-16-2012 09:03:24
| ??? Why? |
| JRSutton
04-16-2012 05:01:35
160.79.139.151
| Never gave it much thought, but I'd imagine if you're going to a separate battery anyways that a deep cycle battery would probably be your best bet. The same kind you'd use on a trolling motor. |
| soundguy
03-23-2012 15:55:05
173.107.224.225
| | on my toy hauler, I have a winch on the gooseneck, and I carry a spare battery for it or jumps for the treasures I go find. I buy a battery that will fit in my truck as well, in case I need help. I usually use a dual terminal battery as well so it has many uses.. it costs a lil more but is handy always having an extra battery on hand when dragging home rusty iron. ps.. you can rig it to charge off the power option on the 7 pin.. kinda like the trailer battery for breakaway.. |
| caterpillar guy
03-21-2012 19:26:37
24.247.25.227
| for the battery get one with the studs on top rather than lead posts. It is easier to hook up and will require less cleaning maintenance. They are like come in the semis. Group 31. |
| 430WLPG
03-18-2012 17:25:33
166.181.3.33
| I ran a 4ga battery cable like a balespear and got a welder qui ck connector then used a group31 battery on trailer and leave the truck running and this way the tru k will charge the battery as you drive also disconnect thr trailer light plug when using winch or it will try to ground through the light plug |
| JimEvans
03-18-2012 18:26:16
66.185.0.208
Re: To buy a separate battery for winch operation? in reply to 430WLPG, 03-18-2012 17:25:33
| Yep. Make sure to disconnect the trailer plug. Especially if using long jumper cables up to the truck battery. If the ground cable isn't tight, it will try to send 300 amps or so through the trailer harness ground. It will burn the wiring harness up all the way from the plug to the battery. Very expensive fix. |
| Cliff Nelson
03-18-2012 09:56:20
96.60.120.179
| As others have said large battery and wire to battery charge terminal on trailer connector. I installed mine in a plastic RV battery box inside the gooseneck next to the spare tire. I also connected it to the breakaway switch for the trailer brakes. It eliminates having to maintain the small battery that came with the trailer. I use a deep cycle battery mainly because it is the same battery we use with the camper if needed. Haven't had any problems with this arrangement. |
| Ralph Bauer
03-18-2012 09:41:11
75.107.19.224
Follow up question in reply to Ralph Bauer, 03-18-2012 08:51:05
| Separate battery box or ok to use tool box, as long as battery is securely fastened? Are vent holes required? If separate, what are good/better/best locations? (Spare tire is mounted on top of GN, winch plate above storage box.) |
| bobs old iron
03-18-2012 09:28:57
97.124.217.34
| you would want the biggest batt cap, so you have the juice to pull whatever you are doing,, as for cables, if you have a 7-plug r-v set-up, you can wire into the batt side of plug to charge while driving, might have to put on isolator or something like that , to keep from over charging/ruining batt.. or can run cables from batt, along frame to back of truck, with plug in ends like on forklift, snowplows. etc/// |
| Ralph Bauer
03-18-2012 09:33:17
75.107.19.224
Re: To buy a separate battery for winch operation? in reply to bobs old iron, 03-18-2012 09:28:57
| Do have the 7 plug RV connection in the bed (F-350,6.0 Ford Diesel), thanks! |
| rustyfarmall
03-18-2012 09:21:11
216.248.71.224
| Use a 12 volt battery of the same basic capacity as what your truck requires, but then run a good, heavy duty, minimum 10 gauge wire from the accessorie terminal on the trailer wiring plug, through the wiring harness, and connect it to the + post of the winch battery. Leave your truck running while you are using the winch, and you will have the benefit of 2 batteries powering the winch. Also, the winch battery will get recharged while driving down the road. |
| Ralph Bauer
03-18-2012 09:36:22
75.107.19.224
Re: To buy a separate battery for winch operation? in reply to rustyfarmall, 03-18-2012 09:21:11
| Not thought of that. Was planning to use a solar panel to keep battery full, since I don't use it much and sunshine's plenty around here. |
| evilboweviel
03-19-2012 12:25:13
75.185.55.222
Re: To buy a separate battery for winch operation? in reply to Ralph Bauer, 03-18-2012 09:36:22
| solar is nice for keeping a charged battery topped off when trailer is not hooked to truck charge battery from truck |
| Chuck Heck
03-19-2012 10:05:45
98.102.161.2
| I use a marine type battery called "Dual Purpose" I got at Autozone, 1000 cranking amps. Like was mentioned here, it is charged by the 12V hot terminal on the trailer plug. The winch is a 10,000 lb Superwinch. |
| mkirsch
03-19-2012 10:04:40
64.80.110.75
You're going to need a LOT of solar panel, even if the sun shines "plenty." Those little "battery maintainer" panels will take WEEKS in full sun to charge a battery after a good winch run.
Definitely consider connecting the winch battery to the truck for charging and normal operation. A winch takes a LOT out of a battery. |
