Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Fouled injector
Walter Buller
03-12-2012 16:52:35
Last Friday I fouled an injector on my 1993 Dodge with a 5.9 Cummins motor. Injector cleaner didn"t help. The injectors are 300 Hp Bosch from a company that no longer carries them, Diesel Care & Performance. I would rather not have to change all 6 injectors because they"re not that old, but my mechanic tells me that if I replace the one fouled injector with one with factory specs, or close to it, the motor will continue to run rough. Do any of you guys have any free advice you"d like to share about this?
Fullthrottle
03-12-2012 21:31:46
 Re: Fouled injector in reply to Walter Buller, 03-12-2012 16:52:35
If you can find the number on it, type it into Google and see what happens. Lots of times number will show up or supersede. I'm sure some one out there has one or something that will work it's just finding that guy. Might try Gomers Diesel (US Diesel parts) in Missoula MT.
welding man
03-12-2012 17:53:17
Send it to a local injector shop. have it dissembled and cleaned. Reset the pop pressure where it was, leave the same nozzle on it that is on it and it should be OK if they don't find anything else wrong with it.
Walter Buller
03-12-2012 19:34:45
 Re: Fouled injector in reply to welding man, 03-12-2012 17:53:17
I took it to two different injector shops today, the oldest ones in the area. The owners both said that the tip needed replacing, that it would do no good to try to clean it.
welding man
03-13-2012 04:35:18
 Re: Fouled injector in reply to Walter Buller, 03-12-2012 19:34:45
Could they not order you a new nozzle. Never had any problem getting new nozzles for Bosch.
