TractorLinks.com
Tractor Transporting Discussion Forum
Re: How often are you On the Floor
welding man
03-01-2012 14:27:34
Some people like automatics, some don't,personally I hate them.Depends a lot on the truck and how it's geared. I have a 24V. Dodge 5 speed with 4.10 rears.Will pull forever in fourth gear. Used to haul auction cars on a 48 ft. 3 car trailer out of Statesville, NC, up fancy gap mountain -7 miles- grossing 25,500.I could top out at about 50MPH with the pedal to the metal,if you hit it right,but if you had to drop back to 3rd gear you had to go to about half throttle or you would over rev. real fast.
soundguy
03-03-2012 18:40:46
 Re: How often are you On the Floor in reply to welding man, 03-01-2012 14:27:34
my 99 ford 450 with a 4.88 rear and auto trans hauls fine. she won't run much past 70.. but will pull a house doing it.... auto tranny don't slow her down none...
soundguy
The tractor vet
03-01-2012 14:41:21
Geee's you need a few more pony's. Grossen 105000 use to top Fancy gap at 70-74 mph in twelveth gear
welding man
03-01-2012 17:43:35
 Re: How often are you On the Floor in reply to The tractor vet, 03-01-2012 14:41:21
Sounds like you might have had a 550 CAT with an 18 Speed too!!! How in the devil did you get through the scales at the bottom of the mountain grossing 105,000? They stopped me for something every time I went through there.
The tractor vet
03-03-2012 06:34:44
 Re: How often are you On the Floor in reply to welding man, 03-01-2012 17:43:35
Well ya had to learn how to Play the scales and 99% of the time i had this little piece of paper that said it was OK. OR ya waited till they went home and turned off the lites . First truck was a 77 International 4300 Eagle with a built 855 small cam with a 13 speed and i can not tell ya what she could put out because the day we dynoed it she broke the chain and went out the door as they could not hold it . The last one was a 98 9400 I H with a 550 Cat with a 13 speed 3.90 rears and a Diesel Injection (now call Pittsburg Power ) box with this little switch that helped . It would go up hills a lot faster then i wanted to go down them. biggest load pulled with the 9400 was just shy of 2600000. the 4300 278800
welding man
03-03-2012 09:49:01
 Re: How often are you On the Floor in reply to The tractor vet, 03-03-2012 06:34:44
Now I know, hauling them permit loads. Takes a Good truck for that kind of hauling in the mountains of NC VA and WV.
snoopnc
03-02-2012 19:09:24
Wondering the same thing about the scales....unless, that is if he went up the "old road" outta Mt. Airy, NC.
welding man
03-02-2012 19:24:00
 Re: How often are you On the Floor in reply to snoopnc, 03-02-2012 19:09:24
Friend of mine tried that a while back and they were set up on the old road in Virginia.Got him for 4500 Lbs over axle on rear. Big fine.
hintocw
03-03-2012 07:02:35
 Re: How often are you On the Floor in reply to welding man, 03-02-2012 19:24:00
When they really sock it to ya if you are caught going down (south) on the old road (US Hwy 52). I had an aquantice try that, got caught, became a guest of the State of Virginia (Carrol Co. jail) for three days before he was able to make bail.
scotc
03-04-2012 23:22:35
 Re: How often are you On the Floor in reply to hintocw, 03-03-2012 07:02:35
A lot of guys will run over to Galax and down 89 into NC. Now and then someone doesn't pay attention and wrecks pretty good. I figure that mountain looks steep enough it ain't worth it.
I took 52 north from Hillsille one time, traffic was backed up almost to Fancy Gap. Can't really say it saved any time, but it was an interesting drive.
snoopnc
03-03-2012 15:53:02
Many, many moons ago...before I-77 was finished across the mountain...I had an occasion to go down that old hwy. at night...in fog...driving a pickup. I SURE don't wanna do it in a big rig...that's a scary bugger!!
hintocw
03-04-2012 04:55:07
 Re: How often are you On the Floor in reply to snoopnc, 03-03-2012 15:53:02
What's REALLY FUN is going down Hwy (State road) 5 from Floyd VA to Stuart VA (in a big truck) especially when the road's wet. Otherwise you have to go about 40 - 50 miles out of the way.
