Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Re: UPDATE: To buy a trailer or not, and if, what kind?
d beatty
02-20-2012 08:50:23
Jim what size truck are you pulling a tri axle with. When i used to have to scale before loading My single axle semi tractor with a 48 foot trailer would scale out at empty at 26,600 lbs. The new 21,000 lbs. tri axle (bumper or GN) run between 5,200 and 6,600 lbs. I know of no factory made pickup that weights 19,000 lbs.
730d se
02-20-2012 09:45:16
 Re: UPDATE: To buy a trailer or not, and if, what kind? in reply to d beatty, 02-20-2012 08:50:23
The basic issue is not the actual weight of each unit, but the total gross weight rating.
If his trailer weight rating is 21,000 LBS, that leaves only 5,000 LBS weight rating for the towing vehicle.
Not going to find a truck with a 5,000 LB or less rating that will pull the trailer.
Again, it is not just about the load, it is about the capabilty of the two together, no matter if empty, loaded, or worse yet, over loaded which gets you in much deeper in your wallet.
He will need at minumum a CDL, million in liabilty, fuel tax and filing all of that every 3 months, etc.
It is more trouble that is is worth unless you are running a full on hauling service, in which case you would likely have a semi.
