Ralph Bauer
Found those 2 definitions on a website, from which I conclude that either ones are all-right with DOT. grade 70 being easier recognized from afar...
Correct? (Just curious since Harbor Freight offers both on sale in Feb. flyer.....)
Gr 43
High Test
This is a higher strength chain used for years in the trucking industry for tie downs that meet DOT specifications. Made from a higher carbon steel, its strength surpasses proof coil working load limits, size for size, by a factor of 2 to 1. Hallmarked every 1 to 3 feet with manufacturer's symbol and grade marking: 4, 40, 43 or 400. Not for overhead lifting.
Gr 70
Transport
As its name implies Transport Chain is used primarily to tie down loads on over-the-road equipment. The yellow chromate (gold) plating makes it easily recognizable even from a distance. Made from heat-treated carbon steel it has about 25% more strength than high test chains. Hallmarked every 1 to 3 feet with manufacturer's symbol and grade marking: 7, 70 or 700. Not for overhead lifting.
Gr 43
High Test
Gr 70
Transport
