Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Trailer Floor - Oak or Treated?
Chuck Heck
10-26-2011 08:00:15
If you had a choice on a new flatbed 14,000 gvw gooseneck trailer, would you get treated lumber or rough sawn oak?
arsalan
11-02-2011 13:42:02
 Re: Trailer Floor - Oak or Treated? in reply to Chuck Heck, 10-26-2011 08:00:15
Depends on your climate, but I'd say PT. And be genereous with used oil. Beats spilling it down the drain ;)
soundguy
11-02-2011 06:38:15
at work we had used oak on out flatbeds.. seems we have to repalce it every 2 ys.
I hve PT on my personal flatbeds and get on average of 10ys out of it.
one of them is a 14k gn as well.
soundguy
old
10-26-2011 10:30:56
Well I have a couple of trailers on hand here. The one with the treated lumber still has a good deck on it and the one with the oak you better be careful if you try to walk on it because you will fall threw it in some places. I also treated the oak with oil and that did not help so if I where you I would go with the treated stuff it will last 3 or more times longer
Zachary Hoyt
10-26-2011 10:24:45
If you can get white oak that makes a great trailer deck as it is rot resistant and harder than PT. Red oak is not as desirable for decking as it will not last as long.
Zach
Hill-Billy Rock-Star
10-26-2011 17:32:33
 Re: Trailer Floor - Oak or Treated? in reply to Zachary Hoyt, 10-26-2011 10:24:45
What works better then oil and way better for the ground water? Thin out Tompson's water seal and put a few coats on . The deck On my gooseneck is about 15 years old and still rock solid. It's oak sits out side in Michigan Weather. Ive treated with Tompson's about 3 times.
rustyfarmall
10-26-2011 08:02:23
Get the pressure treated. Apply a generous amount of used motor oil to it once or twice per year and it will last for as long as you need it.
ShepFL
10-26-2011 09:32:05
 Re: Trailer Floor - Oak or Treated? in reply to rustyfarmall, 10-26-2011 08:02:23
Rustyfarmall -
You better watch out with used oil recommendation :) Few yrs. ago on this same site I got SLAMMED HARD about the same recommendation. Some folks got down right twisted about it; even got the bunny huggers calling me everything but home-made sin.
Thick-skinned and still in the weeds here in FL . . .
rustyfarmall
10-26-2011 13:22:09
 Re: Trailer Floor - Oak or Treated? in reply to ShepFL, 10-26-2011 09:32:05
Yes, I'm pretty sure I was in on that conversation, and like you I am thick skinned also and still maintain that used motor oil is the best preservative for trailer floors.
For what it's worth, I just finished constructing a new front stoop on my house. I built it entirely out of pressure treated lumber and since I need it to be good and solid for at least 20 years, I did some research on maintenance and found out that any kind of water seal, Thompson's or otherwise, is no longer recommended for preserving pressure treated decks. What is recommended is to allow the wood to cure out naturally for at least 6 months, and then paint it with 100% acrylic house paint.
Jim in Ma.
10-26-2011 09:48:47
Mine is PT for the deck and has been on there for 5 or 6 years and still looks good.
And I will still use old motor oil once a year.
My brother uses boiled lynseed oil and at the same age, His needs to be replaced.
ron8
10-26-2011 14:43:24
 Re: Trailer Floor - Oak or Treated? in reply to Jim in Ma., 10-26-2011 09:48:47
i been real happy with my oak floor. Next time i will use hard treated, but definitly not pine.
Copyright © 1997-2015 Yesterday's Tractor Co.
