TractorLinks.com
Tractor Transporting Discussion Forum
Tractor hauler
Brad Buchanan
10-10-2011 15:39:11
I am considering purchasing a road tractor for hauling antique tractors.
I really like the look of this 90 Freightliner amd the money is right.
I want to keep the total weight under 28,000 for license purposes and run standard commercial plates.
Any engines to avoid?? Aluminum trailer?? Comments??
Brad Buchanan
Dmack
10-15-2011 18:32:04
 Re: Tractor hauler in reply to Brad Buchanan, 10-10-2011 15:39:11
That's a good looking ride to be a 90 model. There is some advantage to being an early model as that truck will be mechanical instead of electronic which could be alot better. The electronic operated fuel systems tend to get real exspensive when the components start going bad such as ecm's and computers etc. So that being said I wouldn't be afraid of it provided it runs out ok. I would however check out the license and insurance, because, the state I live in does not reconize that type of truck as a rec vehicle. That makes the use of a road tractor prohibitive for hauling toys around. Then, theres all ways the fuel permit and highway use tax to deal with. I tried that and found it was too much of a headache for no more than I was using it. Just a little insight of things to check. Good luck!
scotc
10-20-2011 21:30:10
 Re: Tractor hauler in reply to Dmack, 10-15-2011 18:32:04
Unless it's a Detroit, the 60 series came out in 86 and I don't think it was ever available with mechanical injection.
But there's enough of them out there, if something too major goes bad you can always find a good used one to drop in it.
Ray
10-15-2011 15:02:40
That's nice looking truck for a 90 model,must have had a good home.
d beatty
10-14-2011 05:46:48
Brad the tractor will handle what your going to do with it. I don't think you will get away with 28,000 lb. plate. That tractor with trailer is going to scale in around 20,000 lbs. no load. That would leave you 8,000lbs. for the load. As for the NOT FOR HIRE commercial carriers that are contracted out use that on their trucks.
So I don't think that will help you a whole lot.
bobs old iron
10-13-2011 06:39:23
like john said, put private carrier on side "not for hire" and get motorhome plates, plus should be cheaper on insurance if they think you use it for your own porpose.
S2710
10-13-2011 19:53:19
 Re: Tractor hauler in reply to bobs old iron, 10-13-2011 06:39:23
I asked the DOT man about the signs on the trucks that say NOT FOR HIRE and he told me that when he sees one of them he checks it out real close to see what they are hiding.
Bob
Brad Buchanan
10-12-2011 08:38:15
Thanks to all who responded. This is just the kind of info I was looking for.
While some think this type of truck is an 'ugly duckling' I think the short turning radius combined with the power available make it a good choice. And I think they look great!
Thanks again,
Brad
JOHNNYfromMI
10-11-2011 20:53:58
Buy a trailor and build living quarters in the front of the trilor and license it as a motor home. Leagle to do here in Michigan. No CDL or scales to worry about, as you won't have to stop at them. Use the back of the trailor to haul your toys.
scotc
10-11-2011 19:22:38
That would be a good truck for you. If you're going to run a gooseneck on it set the hitch way at the back, it will put more weight on the back axle. The trailer also won't track as far to the side in a turn, and even without trailer brakes stopping won't be an issue.
Just remember, there is a reason the old Freightliner cabovers are called freight SHAKERS. But a good set of shocks and a trip to a good alignment shop can take care of a lot of that.
old
10-11-2011 13:22:43
Cat engines are good but cost more to keep running since you pay for the name. Cummins do well and are very common. Detriots are ok for the open road but get do into tight areas where you need a lot of slow pulling power they do not have it. As for that rig I have never likes the singe rear axle rigs and the cab overs are a pain to work on. I drove a binder with a 350 big cam Cumins that was a cab over hard to get in and out of and hard to check things like oil etc.
soundguy
10-11-2011 12:09:08
I've always been partial to the older 80-84 macks.. but that machine loks real celan.. etc.
soundguy
Mike M
10-11-2011 07:55:15
Doesn't anything with air brakes and a 5th wheel hitch really jump up the insurance rates too ?
bobs old iron
10-13-2011 06:35:49
 Re: Tractor hauler in reply to Mike M, 10-11-2011 07:55:15
it shouldn"t, had a 4900 IH with air brakes, pulled my 5th, never got stopped. as long as it doesn"t look like a commercial vehicle
JD PHIL
10-10-2011 19:32:30
I think thats a nice truck to haul toys with,I have drove cabovers alot the rides not bad at all,you wont be riding it 10 hours a day everday should do fine.
sixtyninegmc
10-10-2011 17:58:26
Be aware that cabovers do ride quite a bit rougher than a conventional truck, and have more intensive maintainence requirements. As already mentioned, they turn a lot shorter than a conventional. Any engine should suffice for the weight you will pull, Mercedes engines I would avoid due to spendy parts, and in general the bigger the engine displacement wise, the longer it will last trouble-free at a given HP. In other words, a 425 HP 15 liter cat will still be running long after the 430 HP 12 liter cat dies a spendy death, and will get about the same or better mileage. I would say look for a CAT 3406C or E model, a 60 series Detroit, or an N14 Cummins and you should be okay. Some 60 series before 1997? should be approached with caution.
4010 puller
10-10-2011 17:19:38
What engine and tranny is in it? Good thing about it being cab over and single axle, it will turn on a dime and easy to manuever compared to any other big truck
Super Trucker
10-10-2011 17:08:31
Cool ride. Engine wise there is really no bad choice for what you are doing. My personal likes are CAT,CUMMINS,SERIES 60. Trailer wise I would look for an all alum but look for a 96"wide they are going to be cheaper because everybody wants a 102" and some places won't load a 96". Look at where the suspension mounts for corrosion and cracks along with where the kingpin plate mounts. I would be wary of the trans if it is a SUPER 10spd [THERE IS NOTHING SUPER ABOUT IT!!!!!!] a straight 10spd,13spd,9spd are all great trans but the super 10 has lots of issues. I fear you will be over your 28000lbs. Trailer should weigh 9500-10500lbs for all alum,combo [steel&alum] 10500-12000,all steel 12000 +. Truck should be about 14000 so that doesn't leave a lot of pay load weight. Can you register it as a RV? But if the price is right you would have a hauler to last a life time,oh watch the first step it's a killer.
showcrop
10-10-2011 16:51:23
I could see them going cheap, but I can't imagine anyone liking the looks of them.
